My hatch blew off!!
Old September 5th 09, 02:53 AM posted to rec.aviation.soaring
Default My hatch blew off!!
After all the threads on venting high pressure air overboard I thought
I would share this one with you.
I sealed up the ASW17 canopy and its nice and quiet now.
On Tow yesterday as I retracted the gear the pressure change was
enough to blow the hatch off the top of the turtle deck. I couldn't
figure out what the noise was at first thinking it was a gear door
who's bungy had broken or come unhooked.
I cycled the gear 2 - 3 times more so thinking it might be an animal
or rock or stuck in the gear well.
The noise continued until I performed a sharp pull up from 80 knots.
The rest of the flight was uneventful except there was more air noise
I attributed to a stuck gear door.
The glider had a slight resonance vibration again I attributed it to
the gear door.
Upon landing I was amazed to see the rigging hatch wedged in the
aperture retained by its lanyard and the remaining tape. It was
aligned 45deg. to the airflow which explained the vibration I was
feeling.
So now the fun part....
The ASW17 has a hatch that is exactly dead center of the fuz. so I am
now working on a replacement air exhaust hatch that will replace the
stock "non breathing" hatch. I am looking at a design like the ramp
style that Dick butler has on his ASW22.
More to follow.....
Al
Old September 5th 09, 06:03 PM posted to rec.aviation.soaring
Tim Taylor
On Sep 4, 7:53*pm, "
enough to blow the hatch off the top of the turtle deck. *I couldn't
the gear door.
feeling.
stock "non breathing" hatch. *I am looking at a design like the ramp
More to follow.....
Al
Al,
I think a reverse NACA duct is a better model to use. It will smooth
the transition more and accelerate the air to about equal to the speed
of the outside air for less drag. I would build one similar to the
one in the link but with a cover over about the first half with a
smooth transition toward the back.
http://www.appletreeauto.com/naca-du...4-pr-3425.html
Tim
Old September 6th 09, 06:08 AM posted to rec.aviation.soaring
Al[_7_]
the gear door.
feeling.
More to follow.....
Al
Al,
I think a reverse NACA duct is a better model to use. *It will smooth
of the outside air for less drag. *I would build one similar to the
Tim
But NACA ducts are usually used for inbound air not outbound...
There was another type I saw on a buddies ASH26 but can remember the
name of it began with an E.
Cheers
Al
Old September 6th 09, 07:14 AM posted to rec.aviation.soaring
Tim Taylor
the gear door.
feeling.
More to follow.....
Al
Al,
Tim
Cheers
Al
Actually there are NACA designs for inlets and outlets. They would be
the best design to use for an outlet. Dick Butler's design is close,
but could use some slight modifications to improve the speed of the
exit airflow. In my opinion the Mandl Extractor is not the best
design to use. It has too great of an angle where the air rejoins the
outside airflow.
Old September 7th 09, 02:45 PM posted to rec.aviation.soaring
Peter Higgs
Hi Tim and Al, Perhaps it was just a pressure pulse which blew the cover
off. If you attatch a rear-facing duct you are likely to produce a
negative pressure difference, and an altimeter with an inboard static vent
would read higher than you are.
Perhaps the best initial solution would be to drill a 10-15mm hole in the
access cover, (or anywhere else really.) which depending upon the airflow,
would act as a static vent... neither increasing or decreasing the ambient
pressure.
I wonder if the pressure pulse was created by the closing of the u/c
doors, or because you where using the screen ventilation system, which
admits air onto the screen... Where is that supposed to go ?
Pete
At 06:14 06 September 2009, Tim Taylor wrote:
On Sep 5, 11:08=A0pm, Al wrote:
though=
t
Old September 8th 09, 05:36 PM posted to rec.aviation.soaring
Andy[_10_]
would act as a static vent... *neither increasing or decreasing the ambient
pressure.
pressure.
I'm not sure I would want an "air spigot" pointing straight out of
the fuselage into the airstream - seems like unnecessary drag versus a
solution that lines the flow up with the external slipstream. The
reverse NACA duct has been shown to work well and it's my
understanding that it even produces a small amount of thrust.
As to altimeter readings - my altimeter is hooked to my tailboom
static ports. I'd recommend it as a general practice if you have
external ports available. My feeling is that any solution that vents
high-pressure fuselage air would yield a more accurate altimeter
reading than not venting but that the differences in any even aren't
that large.
9B
Old September 8th 09, 09:32 PM posted to rec.aviation.soaring
cemx86
testing please ignore
Old September 8th 09, 09:45 PM posted to rec.aviation.soaring
ContestID67[_2_]
$52? Here are some other sources for less expensive NACA ducts.
Black and Clear. These come with an intergral "exit" tube at the
larger end. Other sources don't have this tube, just an exit slot the
size and shape of the larger end. Google "naca duct".
Try racerpartswholesale dot com which has both black and clear lexan.
Replace "dot" with a period. Google is blocking this post for some
reason when it contains full URL's.
Thanks.
Old September 9th 09, 07:45 AM posted to rec.aviation.soaring
Al[_7_]
On Sep 8, 1:45*pm, ContestID67 wrote:
$52? *Here are some other sources for less expensive NACA ducts.
Black and Clear. *These come with an intergral "exit" tube at the
larger end. *Other sources don't have this tube, just an exit slot the
size and shape of the larger end. *Google "naca duct".
Replace "dot" with a period. *Google is blocking this post for some
Thanks.
Er Guys these are ducts that are inlet..
I need ones that are outlet...
Carrier Hornet, pt 7 - Pilot House Hatch.JPG (1/1) Mitchell Holman[_3_] Aviation Photos 0 March 17th 09 11:54 AM
GT White Floats out the Open Hatch GPN-2000-001407.jpg [email protected] Aviation Photos 0 April 9th 07 09:02 PM
GT-3 Virgil Grissom shown through window of open hatch on Gemini craft S65-20605.jpg [email protected] Aviation Photos 0 April 9th 07 08:52 PM
I almost blew it today Bill Watson Piloting 6 January 25th 07 12:17 AM
Blew a Gasket jls Home Built 6 June 2nd 04 07:36 PM
