Fuel dumping on the F-111
Old August 26th 04, 10:17 AM
Stuart Chapman
Default Fuel dumping on the F-111
Hi all.
You've all seen the 'cigarette lighter' fuel dump by the F-111 at airshows.
Can the F-111 just dump fuel normally (no fuel ignition)? If not, why not?
Stupot
Old August 26th 04, 10:25 AM
douga play
Stuart Chapman wrote:
Hi all.
Hi
airshows.
not?
I have read that they use after burner to do this... so maybe without AB
they
dump without fire
Stupot
Alex
Old August 26th 04, 12:44 PM
John Carrier
"Stuart Chapman" wrote in message
Hi all.
airshows.
Yes. Burning dumped gas is an airshow trick. RA-5C also did it. F-14
could as well, but it was unauthorized.
R / John
Old August 26th 04, 02:27 PM
Kurt R. Todoroff
While dumping fuel in the F-111, at least minimum afterburner thrust was
required to ignite the fuel stream. Non-afterburner core thrust possessed
insufficient temperature to ignite it since the fan mass flow mixed with the
core combustion products, thus lower its temperature. I would be interested to
know if any turbojet fighters had a fuel fump mast near the engine exhaust, and
if so, could their core thrust alone ignite the fuel stream.
John, I had a copy of the F-14A flight manual until my last move. I seem to
remember that the Tomcat dumped its fuel using only the fuel boost pumps (no
fuel tank pressurization), which yielded a somewhat low fuel transfer rate
through the dump mast. Did the low fuel transfer rate effect a low fuel
exhaust velocity through the dump mast, thus causing the potential for the
flame to contact the fuselage?
The F-111 normal fuel dump mode was accomplished with fuel tanks pressurized.
If memory serves me (I no longer have my Vark flight manual either) normal fuel
dump transfer rate was approximately an order of magnitude greater with tanks
pressurized than with tanks unpressurized. The F-111 had no restriction on AB
use during normal fuel dumping operations, but (again) I can't remember if it
had AB use restrictions during non-pressurized fuel dumping operations.
Perhaps there was language contained in a caution.
Kurt Todoroff
Markets, not mandates and mob rule.
Consent, not compulsion.
Old August 26th 04, 06:42 PM
John Carrier
"Kurt R. Todoroff" wrote in message
interested to
exhaust, and
to
(no
Been so long, I can't remember, but that sounds right. But it was
prohibited and the 100 foot flame trick would work in A/B (don't ask, don't
tell).
pressurized.
fuel
tanks
on AB
it
Kurt Todoroff
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Fuel dumping! Ed Majden Military Aviation 20 October 26th 03 12:32 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
