Netbook Computer For Soaring
Old September 9th 09, 01:02 AM posted to rec.aviation.soaring
Default Netbook Computer For Soaring
I am thinking about buying a Net Book Computer with 10 1/2 inch screen
for use in soaring. In addition to internet access, I would want to
run Seeyou, LXE, Cambridge (dos),and Dr Jacks forecasts. Has anyone
used a Net book for these items and were there any problems? If you
add a USB to serial adapter, did it comunuicate easily with the GPS/
NAV (Cambridge)? I fly with the Cambridge GPS/NAV and a LX 7007.
Need to load turnpoints with serial port to GPS/NAV and be able to
download flights from GPS/Nav via serial port. The comuincation with
LX 7007 is via SD Chip or serial port through the LXE software. What
make and model Netbok do you recommend?
Bill Snead
6W
Old September 9th 09, 01:53 AM posted to rec.aviation.soaring
JS
I've used BLIPMAPS, XCSkies and other forecasting tools on an HP
netbook sold through Verizon. The height of the screen is ok but not
great for maps.
Have not connected it to a GPS.
The netbook gets online all over the place, and connection speed is
decent. It has USB (would require the same adapter as other computers
without serial port) and an SD card reader. It fits easier than any
other laptop in the baggage compartment or perhaps even behind the
seat.
Old September 9th 09, 02:06 AM posted to rec.aviation.soaring
BT
I have an Acer One NetBook that I used last summer on a soaring safari to
Tonopah NV.
IT WAS GREAT !!!
The screen is 7.5 in wide, 9 in diagonal. Mine is one of the "first
generation" netbooks with 120GB internal HD, not the SSD drive and it runs
WinXP just fine. I also have Office2007Home loaded.
My NetBook did not have the built in Broadband, just the built in wifi., The
hotel lobby had free wifi.
I bought an external VirginMobile USB Broadband access capability that ran
just fine. No set charges and Pay as you go access, I can turn it on or off
month to month. A weeks soaring and other evening activity I used about
150MB of the 200MB I paid for the month. The FBO at the airport also had
limited wifi access but the USB Broadband was much faster.
My AcerOne has two SD ports, so loading a task or downloading post flight
data via SD card is no problem. The Colibri uses the microSD cards, but when
you buy a microSD card they come with the "adapter" to full size SD.
VirginMobile USB Month to Month, is much cheaper than Verizon or Sprint
Contract costs. Just check your coverage areas for where you will be flying.
Cricket also has the same "pay as you go" 3G access.
I run SeeYou for task planning and review. SeeYou worked great with the USB
connection to the Colibri data logger for setting tasks and downloading
files.
I was also able to use a USB to Serial Cable to download GPS data from a
Garmin 76S Handheld either with SeeYou or a GPS data grabber utility. My
older Garmin 76 has the 4 pin to serial cable. A Serial to USB had no
problems. Sometimes it would kick as to which CommPort it wanted to
communicate on. But after that was figured out, no problems. (Serial is very
slow data transfer).
I use XC-Skies for weather forecasting, but Dr Jack would be about the same.
With the short screen, just need to scroll up and down to see the full
picture.
I also have a small mouse to use with major work instead of using the touch
pad mouse all the time. It would work just as well with a wireless bluetooth
mouse. With 3 USB ports it was fine. Also mine has two SD slots. One for
"transferring data" the other slides in farther and a 16GB SD card could be
used as a second internal storage device.
I have not used it for LXE or Cambridge devices.
BT
email at bee tee eye zee two @ cox.net
Bill Snead
6W
Old September 9th 09, 03:00 AM posted to rec.aviation.soaring
Tuno
Bill, if you haven't seen it already, Wikipedia has a nice comparison
table he
http://en.wikipedia.org/wiki/Comparison_of_netbooks
I'm giving the technology another year before I pick one. (And no, I
don't expect the pace of miniaturization to have leveled off a bit!)
~ted/2NO
Old September 9th 09, 05:31 AM posted to rec.aviation.soaring
Mike Bamberg
table he
~ted/2NO
I've been using an MSI WInd for several months and am very happy with
it as a very portable computer. Took it to China and have used it all
over the US, easy hook up to WiFi and SeeYou works fine. The only
problem is with programs that use ONLY 1024 by 768 or larger screens;
the netbooks are 1024x600 and several programs I've loaded to use
either fall off the bottom and you loss what ever controls are there,
or they refuse to work at all.
None of the soaring programs or websites have caused any problems.
Old September 9th 09, 05:56 PM posted to rec.aviation.soaring
ContestID67[_2_]
Did SeeYou 3D work OK with your netbook? That is the real CPU and
video hog of the various things that SeeYou can do. Obviously,
statistics, plan or elevation views are no big deal.
I suggest that you make sure to buy a unit with an Atom processor and
pay for 2gb of RAM. They all seem to come with a webcam which is
great with Skype.
My wife bought a Dell Mini10 for $1 (yes, one dollar) from Sprint and
it came with a built in cellular broadband card - a very sweet, use-it-
anywhere combo - but she had to sign up for 2 years of service at $60/
month. ;-( I don't know if this deal is still available.
My $0.02.
- John DeRosa
Old September 9th 09, 10:48 PM posted to rec.aviation.soaring
GK[_2_]
for use in soaring. *In addition to internet access, I would want to
run Seeyou, LXE, Cambridge (dos),and Dr Jacks forecasts. *Has anyone
used a Net book for these items and were there any problems? *If you
NAV (Cambridge)? *I fly with the Cambridge GPS/NAV and a LX 7007.
download flights from GPS/Nav via serial port. *The comuincation with
LX 7007 is via SD Chip or serial port through the LXE software. *What
Bill Snead
6W
- Has anyone been able to use Mac for the same purpose?
Does seeyou only run via the windows emulator?
How about serial communication with Cambridge?
After the never ending vista fiasco and being able to play with my
significant others macbook, I think I'd like to land with a macpro...
GK
Old September 9th 09, 10:58 PM posted to rec.aviation.soaring
Mike Bamberg
Bill Snead
6W
*- Has anyone been able to use Mac for the same purpose?
GK
Yes the 3D function of SY worked fine on the netbook.
Old September 9th 09, 11:37 PM posted to rec.aviation.soaring
John Smith
Face it, gliding software is mostly windows only. Seeyou does run on a Mac
- perfectly with Windows on Bootcamp
- perfectly except 3D with Windows over Parallels or Fusion
- acceptably with WINE (so I've been told), but without 3D
Most USB-to-serial adapers work just fine on Macs with most
applications. I've used one with Windows on Bootcamp with good success
(not gliding related), no idea how they work with Parallels or Fusion.
Old September 11th 09, 02:08 AM posted to rec.aviation.soaring
[email protected][_2_]
Thanks for all the valauble info. Sounds like I really need a
netbook. If I want to use the Virgin Broadband month to month
internet access without using the external USB plug in device, can I
buy a net book that has an internal connection to the internet through
Virgin Broadband?
Bill Snead
6W
Computer help (Got) [email protected] Home Built 3 July 26th 08 03:55 AM
New computer Cal Vanize Simulators 0 April 6th 06 05:28 AM
Borgelt B100 soaring flight computer for sale [email protected] Soaring 0 January 20th 05 01:07 AM
Best lap top computer value for Soaring Snead1 Soaring 7 May 25th 04 06:39 AM
Soaring Flight Computer Comparison - Help needed Paul Remde Soaring 10 January 29th 04 07:35 PM
