Sub-Launched SAMs
Old September 17th 09, 05:07 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Default Sub-Launched SAMs
"Once more, developers are working on weapons that
enable submerged submarines to attack aircraft overhead.
There was recent successful test of the U.S. Tomahawk
Capsule Launching System (TCLS) releasing a AIM-9X
Sidewinder air-to-air heat seeking missile. This is all part
of an effort that began during the Cold War, particularly for
non-nuclear subs. While most of this work halted when the
Cold War ended in 1991, it has since been resumed.
Last year, for example, Germany successfully tested
launching anti-aircraft missile from a submerged submarine
(U-33, a Type 212 equipped with Air Independent Propulsion).
The IDAS (Interactive Defense and Attack system for
Submarines) missile used is 7.6 feet long, 180mm in diameter
and weighs 260 pounds. It has a 29 pound warhead and a
range of at least 15 kilometers. The main targets are ASW
(Anti-Submarine) helicopters and low flying ASW aircraft."
See:
http://www.strategypage.com/htmw/hts.../20090917.aspx
I always thought sub-launched SAM's were a bad idea, since they
give away the position of the launching sub. But the idea refuses
to die.
Why?
Old September 17th 09, 05:38 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Andre Lieven
See:
give away the position of the launching sub. *But the idea refuses
to die.
Why?
Probably for the same reason that the idea of merging battleships
and aircraft carriers in one hull refused to die, too, yet almost
never
actually saw the light of day in terms of a ship such as that being
*built*.
Ise & Hyuga were conversions, of course.
There are plenty of bad ideas that just hang around almost forever:
"reality shows", "US health care is #1!", and so on. That doesn't
mean that they are either 1) good or 2) true.
Andre
Old September 17th 09, 05:40 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Dennis[_6_]
See:
to die.
Why?
As they said on NL's "Animal House," why not?
Like nuclear grenades.
Last May, Stickley gave a PowerPoint briefing to a review panel in
which he promoted the hafnium program as the next revolution in warfare.
Hafnium bombs could be loaded in artillery shells, according to a copy of
the briefing slides, or they could be used in the Pentagon's missile
defense systems to knock incoming ballistic missiles out of the air. He
encapsulated his vision of the program in a startling PowerPoint slide: a
small hafnium hand grenade with a pullout ring and a caption that read,
"Miniature bomb. Explosive yield, 2 KT [kilotons]. Size, 5-inch
diameter." That would be an explosion about one-seventh the power of the
bomb that obliterated Hiroshima in 1945.
http://www.washingtonpost.com/ac2/wp-dyn?
pagename=article&contentId=A22099-2004Mar24&notFound=true
Old September 17th 09, 08:01 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Dean
See:
to die.
Why?
* * * * As they said on NL's "Animal House," why not?
* * * * Like nuclear grenades.
* * * * Last May, Stickley gave a PowerPoint briefing to a review panel in
I'm surprised the 9/11 conspiracy folks haven't connected with the
hafnium/nuclear grenade folks.
Old September 17th 09, 08:17 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
vaughn[_2_]
to die.
The obvious first answer for that is that once an ASW aircraft has found
you, your position has already been "given away". Downing that ASW aircraft
might be very helpful to the sub's subsequent attempts to break off contact.
Also, it seems to me that the ASW problem becomes greatly complicated if the
ASW forces are denied safe & unopposed command of the airspace.
Vaughn
Old September 17th 09, 08:43 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
David V. Loewe, Jr
On Thu, 17 Sep 2009 09:38:41 -0700 (PDT), Andre Lieven
If US health care isn't #1, why have you run away from the discussion in
rasff, Andre?
"Does any one know where the love of God goes
When the waves turn the minutes to hours?"
Gordon Lightfoot
Old September 17th 09, 08:59 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Paul J. Adam[_3_]
In message , vaughn
writes
The problem is that the MPA may be simply sweeping and missed you
completely, or had a mere sniff that it can't confirm... until you
launch a SAM at him, thus going from POSSUB to CERTSUB and definitely
hostile (and the next MPA or ASW cab is likely to be on-scene before you
can clear datum very far).
There's a further problem that the sub-launched SAM is not going to have
the greatest of Pk - it's being launched on "aircraft somewhere up
there, probably" which isn't the best way to ensure a
heart-of-the-envelope shot against a target that may have a decent DAS.
Disputing air superiority is a better way to do that, than sub-launched
SAMs.
It's one of those ideas that keeps popping up, and keeps turning out to
be less attractive when worked through in detail.
He thinks too much, such men are dangerous.
Paul J. Adam
Old September 17th 09, 09:25 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Dennis[_6_]
Shhhhhhhhh... not so loud!
Dennis
Old September 17th 09, 09:29 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Dennis[_6_]
never
*built*.
Battleships themselves are a bad idea that won't go away.
Like the proverbial bad penney! What about pennies, for that matter?
Dennis
Old September 17th 09, 09:33 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
William Black[_1_]
Paul J. Adam wrote:
In message , vaughn
writes
aircraft
contact.
if the
SAMs.
Didn't someone once talk about putting something like Rapier on the top
of a submarine periscope to knock down impertinent helicopters?
William Black
"Any number under six"
The answer given by Englishman Richard Peeke when asked by the Duke of
Medina Sidonia how many Spanish sword and buckler men he could beat
single handed with a quarterstaff.
one of uncle sams aircraft? John A. Weeks III General Aviation 1 September 12th 06 09:18 PM
one of uncle sams aircraft? Eeyore General Aviation 1 September 10th 06 04:19 AM
one of uncle sams aircraft? Stubby General Aviation 0 September 9th 06 11:11 PM
Good prices on Aeroshell oils at Sams club Fastglasair Home Built 4 October 2nd 04 11:30 PM
Will LPI radar be used to guide SAMs? Chad Irby Military Aviation 6 January 4th 04 09:02 PM
