good news for wood builders
Old September 18th 09, 10:52 AM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
Default good news for wood builders
I love good news like this.
I went down to buy some queensland hoop pine marine plywood for my
Turbulent today. I was asking the plywood supplier I use about the
availability of plywood in 0.8mm or 1mm for the tail surfaces.
the original maker in finland of finnish birch ply closed down some
time last year and the thinner plywood vanished leaving 1.5mm as the
thinnest available.
however there is a new firm currently ramping up to production again.
evidently there is not enough demand for GL1 aviation grade plywood so
the new stuff will be GL3 marine grade plywood.
my local supplier tells me we should have birch plywood available
again in a few months.
birch ply in marine grade should still be quite usable in aircraft
work though.
so Druine D3 Turbulent, Jodel D9, Corby Starlet anyone?
you'll never regret building a little single seat wooden aeroplane.
open cockpits in warm balmy weather is the best medicine.
Stealth Pilot
The news is in. It's not good for the FAA Mike Instrument Flight Rules 0 June 23rd 09 08:16 PM
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes flybynightkarmarepair Home Built 7 January 6th 07 04:22 PM
(",) .............. Good News Everyone! .............. [email protected] Owning 0 January 26th 05 09:56 PM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 03:06 AM
SURVEY on manuals - most important for builders, but never good?? T-Online Home Built 0 January 23rd 04 04:37 PM
