Bum Dope
Old October 23rd 03, 08:46 PM
Veeduber
Default Bum Dope
23 October 2003
I recently told a fellow he should be using a different cam in his engine.
Later messages made it clear I had been talking to the wrong guy. (I get lots
of mail.) Trouble is, now I can't remember WHO I was talking to. So here's a
general retraction, cross-posted.
If you're planning to fly behind a stock 1600cc VW engine I think you should
keep the stock cam. That assumes you're swinging a long, efficient prop at
2500 to 3000 rpm. The cam I referred you toward does fine on big-bore strokers
but does WORSE than the stock cam when used on engines having displacement of
120cid or less. (Stock is about 96cid; 1834 is about 112.)
If you went ahead and bought the other cam, I'll buy it off you.
-R.S.Hoover
Old October 24th 03, 02:33 AM
Del Rawlins
On 23 Oct 2003 11:46 AM, Veeduber posted the following:
23 October 2003
engine.
get lots of mail.) Trouble is, now I can't remember WHO I was talking
to. So here's a general retraction, cross-posted.
should keep the stock cam. That assumes you're swinging a long,
efficient prop at 2500 to 3000 rpm. The cam I referred you toward
does fine on big-bore strokers but does WORSE than the stock cam when
used on engines having displacement of 120cid or less. (Stock is
Class act. Hopefully you'll catch him in time.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
What other industry uses butyrate dope? Michael Horowitz Home Built 0 August 17th 03 06:59 PM
