Avionics - engine related static
Old September 23rd 09, 04:45 AM posted to rec.aviation.soaring
Ed
Default Avionics - engine related static
Over the last year or so I've noticed a gradual increase in engine-
related radio and intercom static in my Grob 103 SL. I've checked the
grounding of the ignition system and I am using R-type spark plugs.
The interesting feature of this static is that I can make it go away
completely if I tug a bit on the airbrake handle (not enough to
release the brakes, just a gentle pressure). Releasing the pressure
causes the static to reappear.
I'm wondering if this pressure exerts force on a bulkhead or metal
fitting that is somehow connected to a ground that has become
intermittent and makes better contact with the pressure. Any avionics
techs out there with advice on how to troubleshoot this problem?
Radio Static When Engine Runs ECB Owning 9 November 6th 05 02:46 PM
Engine doesn't make minimum static rpm Bob Fry General Aviation 5 June 21st 05 04:18 PM
Engine doesn't make minimum static rpm Bob Fry Owning 5 June 21st 05 04:18 PM
Get listed in the only Aviation related Pay per click search engine!!! Larry General Aviation 1 August 3rd 03 12:00 AM
Get listed on the only Aviation related Pay per click Search engine!!! Justin Case Products 0 August 2nd 03 12:10 PM
