Hello
Young friend of mine is finishing his EAA Biplane , he would like to mount the detector/antenna inside the fabric so as to not show on the outside of upper center section , the airplane is in the silver/aluminum stage of painting , the alum. powder in primer is used to block UV , he is wondering if it could also block the RF from the Sats., I told him that we might get an answer off the group. Thanks Phil L. |
Phil a écrit:
Hello Young friend of mine is finishing his EAA Biplane , he would like to mount the detector/antenna inside the fabric so as to not show on the outside of upper center section , the airplane is in the silver/aluminum stage of painting , the alum. powder in primer is used to block UV , he is wondering if it could also block the RF from the Sats., I told him that we might get an answer off the group. Just try, it may work.... -- 02°44'45"E 45°30'50"N Philippe Vessaire Ò¿Ó¬ |
![]() "Phil" wrote in message ... Hello Young friend of mine is finishing his EAA Biplane , he would like to mount the detector/antenna inside the fabric so as to not show on the outside of upper center section , the airplane is in the silver/aluminum stage of painting , the alum. powder in primer is used to block UV , he is wondering if it could also block the RF from the Sats., I told him that we might get an answer off the group. Thanks Phil L. If alum powder particles are small enough to be mostly encapsulated by the primer so that conductivity of the finished surface is poor, the attenuation might be low (high conductivity will attenuate the signal). Make a test patch slightly bigger than the GPS antenna. Set up the GPS to look at the sats received power (most GPSs have this capability). Move the finished patch over the antenna and watch the received power. There is a very good chance it will work. It all depends on the amount of Al powder in the mix. J. Severyn AF6QO RV-9A N79LH |
![]() "Philippe" wrote in message news:2548283.koFCf946Em@GastonCoute... Phil a écrit: Hello Young friend of mine is finishing his EAA Biplane , he would like to mount the detector/antenna inside the fabric so as to not show on the outside of upper center section , the airplane is in the silver/aluminum stage of painting , the alum. powder in primer is used to block UV , he is wondering if it could also block the RF from the Sats., I told him that we might get an answer off the group. Just try, it may work.... How about making an inspection hatch for the antenna to be under, and make the hatch out of fiberglass, or colored Plexiglas, or some other RF transparent cover that does not need to be UV protected. I have no doubt that you will need to be getting to the antenna once in a while anyway, so that would kill two birds with one stone. -- Jim in NC |
Antenna under fabric in welded tube ship? | Jon[_6_] | Home Built | 7 | April 27th 08 06:50 PM |
Garmin GA56 GPS antenna | [email protected] | Home Built | 1 | September 12th 07 02:31 AM |
antenna for Garmin GPS in C172 or C152 | d&tm | Piloting | 7 | May 8th 07 02:12 AM |
Garmin 95 antenna needed | Marty from Florida | Owning | 0 | February 19th 06 08:48 PM |
Garmin remote antenna | Dave | Piloting | 3 | December 18th 05 11:58 AM |
