#31
an interesting in flight experiment
On Oct 19, 6:49*pm, "Peter Dohm" wrote:
"-b-" wrote in message ... In article , says... Isn't English fun? Not bad, but I'll bet you never tried or even tasted French! KA What's wrong with French? It's the only place where saying "Pitot" comes naturally! ;-) I've been outdone! Peter There are places in the US where one would not say pitot in mixed company because you may be escorted out the door with a pitchfork. Been there, don't want to go back. |
#32
jan olieslagers wrote:
Ross schreef: I ... squawked the aircraft upon landing. Ross, what do you mean by "squawking a plane upon landing?" I only know the verb in a transponder context. Squawk, write-up and snag mean about the same when applied to notifying the service group about aircraft systems misfunctions. Brian W |
#33
-b- wrote:
Reading the posts here I believe there may be confusion between two different, but related issues. Why do we have two mags per engine and two spark plugs per cylinder? The main reason is redundancy, and the secondary reason is performance. On the performance side, losing one mag in flight should produce a slight decrease in performance, but no really significant roughness or danger to the engine. The function of both mags is detected through the single-mag check on runup. A far more likely occurrence however is the failure of a sparkplug in one cylinder. This goes almost undetected if both mags are working, but will produce very significant roughness on the single-mag check, and will produce a considerable imbalance in operation. So on the redundancy side the mag check serves not only to detect a faulty mag, but more likely to detect a faulty spark plug. If you never did the single mag check, you could theoretically run for some time with a defective plug or even more than one. Then the day you have a mag failure you are at risk of a rapid engine failure. Good point. I had a mag failure on a night flight with an instructor long ago, from Tulsa to Oklahoma City. The engine sounded rough, and the instructor suggested a mag check: one side led to a slight reduction, the other to a rapid tailoff of RPM. So we turned tail. Brian W |
#34
Ross schreef: I ... squawked the aircraft upon landing. Ross, what do you mean by "squawking a plane upon landing?" I only know the verb in a transponder context. We use that word to make write ups on the squawk sheet that they had for each airplane, describing what is wrong. That is what they called it a squawk sheet. I looked at dictionary.com for the definition of squawk. I am not sure it would apply for this or a transponder. The definitions came back as: 1. to utter a loud, harsh cry, as a duck or other fowl when frightened. 2. Informal. to complain loudly and vehemently. A little harsh meaning -- Regards, Ross C-172F 180HP Sold KSWI |
#35
John Clear wrote:
In article , jan olieslagers wrote: Ross schreef: I ... squawked the aircraft upon landing. Ross, what do you mean by "squawking a plane upon landing?" I only know the verb in a transponder context. Squawk in this usage is a maintenance issue. In the US, it is common for a plane to have a 'squawk sheet' aka maintenance log that pilots can note issues on. If the transponder wasn't working, you'd squawk it for not squawking. Isn't English fun? John That was good! -- Regards, Ross C-172F 180HP Sold KSWI |
#36
On Oct 20, 12:16*pm, Ross wrote:
jan olieslagers wrote: Ross schreef: I ... squawked the aircraft upon landing. Ross, what do you mean by "squawking a plane upon landing?" I only know the verb in a transponder context. We use that word to make write ups on the squawk sheet that they had for each airplane, describing what is wrong. *That is what they called it a squawk sheet. I looked at dictionary.com for the definition of squawk. I am not sure it would apply for this or a transponder. The definitions came back as: 1. to utter a loud, harsh cry, as a duck or other fowl when frightened. 2. Informal. to complain loudly and vehemently. A little harsh meaning -- Regards, Ross C-172F 180HP Sold KSWI We've all heard 'squack ident', but I laughed out loud when a controller told me to 'strangle the parrot'. Yes, he meant put the transponder to standby. |
#37
On Tue, 20 Oct 2009 11:16:41 -0500, Ross wrote in :
We use that word to make write ups on the squawk sheet that they had for each airplane, describing what is wrong. That is what they called it a squawk sheet. I looked at dictionary.com for the definition of squawk. I am not sure it would apply for this or a transponder. The definitions came back as: 1. to utter a loud, harsh cry, as a duck or other fowl when frightened. 2. Informal. to complain loudly and vehemently. A little harsh meaning I didn't realize that I didn't know how to spell the word correctly until I read your post. I've been reading it without difficulty since I subscribed to Flying magazine in the mid-60s. What a word! Marty -- Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.* See http://www.big-8.org for info on how to add or remove newsgroups. |
#38
In article ee751f57-50ce-40fa-8bd2-8c3253201138
@e34g2000vbc.googlegroups.com, says... On Oct 19, 6:49*pm, "Peter Dohm" wrote: "-b-" wrote in message ... In article , says... Isn't English fun? Not bad, but I'll bet you never tried or even tasted French! KA What's wrong with French? It's the only place where saying "Pitot" comes naturally! ;-) I've been outdone! Peter There are places in the US where one would not say pitot in mixed company because you may be escorted out the door with a pitchfork. Been there, don't want to go back. Why's that? Where's that? What does it mean "down there"? -- Duncan. |
#39
Dave Doe wrote:
.... There are places in the US where one would not say pitot in mixed company because you may be escorted out the door with a pitchfork. Been there, don't want to go back. Why's that? Where's that? What does it mean "down there"? I could only think of the places that think of the fried articles as Freedom Fries Brian W |
#40
On Oct 20, 8:33*pm, brian whatcott wrote:
Dave Doe wrote: ... There are places in the US where one would not say pitot in mixed company because you may be escorted out the door with a pitchfork. Been there, don't want to go back. Why's that? Where's that? What does it mean "down there"? I could only think of the places that think of the fried articles as Freedom Fries Brian W As a way off topic response, I live in North Carolina, home of "I bet I can deep fry that". For proof, our State Fair is going on now, and there are deep fried Coca Cola soaked breads, pickles, candy bars, . . . It might have been here that chicken fried steak was invented: start with a great steak, coat it with bread crumbs, and fry until well past well done. The airspace above the Fair should be restricted -- it may be CAVU but the vapors on your windscreen will make it actual IMC in the cockpit. Of course, your engine will run rich, ingesting a near explosive mixture of air and grease vapor. And drag goes down too -- but be careful exiting your low winged airplane, the traction you expect will not be the grease does that. Close by are some of the better heart hospitals in the country. Coincidence? I think not. Now, back to the regularly scheduled program. |
Similar Threads | ||||
Interesting and different flight on OLC | Dave Nadler | Soaring | 2 | August 4th 09 01:06 PM |
Solar Flight Much more interesting than Hilarious Video | Richard[_1_] | Soaring | 0 | December 5th 08 04:07 PM |
Interesting 2-plane takeoff at BWI 4-28-06 (formation flight) | Gary G | General Aviation | 2 | May 1st 06 08:42 PM |
An interesting trial flight attempt... | [email protected] | Soaring | 35 | February 12th 06 07:31 PM |
A small experiment | Mike Borgelt | Soaring | 16 | May 6th 05 06:41 AM |
