Blanik L23 repaint
Old October 24th 09, 01:43 AM
tomcatvf51 tomcatvf51 is offline
Junior Member
First recorded activity by AviationBanter: Oct 2006
Default Blanik L23 repaint
Our club is repainting/recovering the ailerons, wings and horizontal tail of our 1999 Blanik L23. Our supervising A&P and I are stymied in the disassembly of the horizontal tail. The trim tab cable runs from a rocker arm near the forward horizontal tail attachement point through the stab and elevator to the trim tab. It appears that we will have to grind off the swage fitting to release the cable so we can separate the stab and elevator. Everything else on the ship comes apart easily, what are we missing. Suggestions?
- Barry
Old October 24th 09, 02:41 PM posted to rec.aviation.soaring
Barry,
We had the same experience with an L-13 last winter. Our solution was as you suggested, grind of the swage fittings.
"tomcatvf51" wrote in message ...
- Barry
tomcatvf51
Old October 24th 09, 03:12 PM posted to rec.aviation.soaring
Christopher Lyons
On 24 Oct, 09:41, "Wayne Paul" wrote:
Barry,
"tomcatvf51" wrote in . ..
tail of our 1999 Blanik L23. *Our supervising A&P and I are stymied in
the disassembly of the horizontal tail. *The trim tab cable runs from a
the stab and elevator to *the trim tab. *It appears that we will have
the stab and elevator. *Everything else on the ship comes apart easily,
what are we missing. *Suggestions?
- Barry
tomcatvf51
I thought the two trim cables could be disconnected through the
inspection ports where you adjust the tension on each cable so the
trim tabs are aligned.
Old October 26th 09, 03:37 AM posted to rec.aviation.soaring
We just did this work on our 92 L-23. On our Blanik the cable was
attached to the trim tab control horn by an eyelet type of thing. The
cable was wrapped around the outside of this eyelet and then joined to
itself with a wrapped wire and soldier. We removed the soldier and
the wrapped wire and were then able to detach the trim tab.
Blanik L23 AD tomcatvf51 Soaring 0 February 12th 09 12:52 PM
Blanik L-13 AD [email protected] Soaring 7 February 3rd 08 08:01 AM
Blanik L-23 BDS[_2_] Soaring 7 June 27th 07 03:35 PM
Blanik L-13 brien Soaring 0 December 5th 04 02:00 PM
Blanik L-23 Duane Eisenbeiss Soaring 8 April 27th 04 05:53 AM
