Any Moldless Composite Designed Amphibians?
Old November 10th 09, 03:43 AM posted to rec.aviation.homebuilt
durabol[_2_]
Default Any Moldless Composite Designed Amphibians?
I was wondering if their are any moldless composite designed
amphibians? I am definitely not an aeronautical engineer and don't
want to try to design something. Some examples of this type of
construction a Long-EZ, Cozy, Quickie, Q-200, Vari-Eze, Velocity
I know their are some drawbacks to this type of construction: mainly
that the strength to weight is less compared to molded parts, the
surface finish needs a lot of work and it must be stored out of the
sun.
Brock
Old November 11th 09, 01:00 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
sun.
Brock
I'm not sure if the Glass Goose was moldless or premolded - it was
kind of a mess anyway, the blunt aft sections of the fuselage shed
vortices into the pusher prop, and produced uncommanded yaws at
cruising speed of 20-30 degrees. Gary Legare was the genius behind
that design.
Looks pre-molded: http://www.glassgoose.com/index.html
Hopefully they fixed the aerodynamic problem with vortex generators or
a redesign.
Peter van Dine out of Annapolis designed and built the Merganser:
http://www.1000aircraftphotos.com/Co...lborg/9192.htm
http://www.eaachapter478.org/Newslet...Newsletter.pdf
Look for a photo of a COMPLETELY different amphib also built by Pete.
Merganser Aircraft
7656 Binnacle Ln, Owings, MD
(410) 741-5075‎
Air Shark, Seawind, those were definitely pre-molded.
Flying Pants designed for relief in flight [email protected] Soaring 16 May 21st 09 10:59 PM
What a/c is this and what was it designed for? Bruce R Aviation Photos 4 March 22nd 07 02:48 AM
Aviation Websites Designed for Small Screens [email protected] Piloting 2 November 22nd 06 06:26 PM
Re-designed Industrial Classifieds and Auction website. Lenny C Aviation Marketplace 0 March 10th 06 12:34 AM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
