Keys to flying in ground effect:
Old November 25th 09, 01:47 AM posted to rec.aviation.homebuilt
durabol[_2_]
Default Keys to flying in ground effect:
-want sensitive control so can react quickly to "squirelyness"
-large stabilizer (perhaps a stabilator) and longish tail boom
-optimized control surfaces for good control at low speed
-best to fly only in low wind
-long tow rope to avoid turbulence of or crashing into boat
-anything missing?
Brock
Old November 25th 09, 01:19 PM posted to rec.aviation.homebuilt
vaughn[_2_]
"durabol" wrote in message
....which will quickly lead to a PIO, given an inexperienced pilot. I don't know
exactly what you are planning, but go to a gliderport and get some aero tow
experience before you go any further.
-anything missing?
I don't know exactly what you are planning, but I earnestly suggest that you go
to a gliderport and get some aero tow experience before you go any further.
http://www.ssa.org/sport/wheretofly.asp
Vaughn
Old November 25th 09, 04:33 PM posted to rec.aviation.homebuilt
"vaughn" wrote in message ...
-anything missing?
Vaughn
I totally agree with Vaughns. Sensitive controls with quick reaction is very likely to lead to over-reaction. In the initial part of a glider aero tow, when the glider is airborne and the tow plane isn't, you will rapidly learn what is like to fly in ground effect.
As a side note: You may even find flying gliders fun!!
http://www.soaridaho.com/
bildan
On Nov 25, 6:19*am, "vaughn"
...which will quickly lead to a PIO, given an inexperienced pilot. *I don't know
-anything missing?
to a gliderport and get some aero tow experience before you go any further.http://www.ssa.org/sport/wheretofly.asp
Vaughn
I strongly agree with Vaughn - learn aero tow first. It's not
trivial.
If possible, fly a Grob 103 in ground effect. It has an interesting
behavior that illustrates some of the issues. Mainly, the center of
lift moves forward in ground effect reducing pitch stability and
making the elevator about twice as sensitive as it is out of ground
effect.
Most existing G103's have been damaged at least once due to PIO's in
ground effect - although some of this is due to a peculiar wheel
bounce effect.
Old November 25th 09, 07:31 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
-anything missing?
Brock
We all start learning somewhere... So yes, there is quite a bit missing.
First and foremost - learn how to do center of gravity calculations
and how to find the center of pressure (Lift) of your wing and tail surfaces.
Then, learn about the relationship between CG and the center of lift and
how that relationship determines stability. A forward CG will give you
that "squirleyness". Correcting the CG/CP relationship will correct it.
A large tail area and long tail arm won't fix instability.
Flying in low wind for sure, but which way???
Which way do the birds fly?
The tow rope could be an interesting problem that could actually be dangerous.
Two parts -
1) where the rope attaches to the aircraft? Will that impart a pitch moment?
2) Jerk. (4th derivative of motion) What happens when the rope suddenly
goes taught? What about if that happens in flight?
Old November 26th 09, 08:37 AM posted to rec.aviation.homebuilt
Oliver Arend
*A forward CG will give you that "squirleyness". *Correcting the CG/CP relationship will correct it.
You mean "a forward CP", so the distance between CG and CP will be
shorter!?
That's contrary to what I learned, so please explain further.
Oliver
Old November 26th 09, 12:07 PM posted to rec.aviation.homebuilt
Brian Whatcott
Oliver Arend wrote:
A forward CG will give you that "squirleyness". Correcting the CG/CP relationship will correct it.
shorter!?
Oliver
Increased 'tail volume' as it's sometimes called, can promote dutch roll....
Brian W
Old November 26th 09, 09:18 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
shorter!?
Sorry, you are right. That would be an an AFT CG problem.
CG is ahead of CP by some distance, and a download on the tail
holds the nose up.
Oliver
Stability is a CG/CP issue.
Old November 26th 09, 10:36 PM posted to rec.aviation.homebuilt
Anyolmouse
-anything missing?
Brock
Some reading for you-
http://www.angelfire.com/on/dragonfl...teroflift.html There
are what appears to be some typos in it and he also states that the
stall (of the wing) is because of low airspeed. Hmm! I was taught that
it was caused by too much angle of attack. But, some good info in this
page in my opinion.
We have met the enemy and he is us-- Pogo
Anyolmouse
Ground effect effectiveness Tony General Aviation 14 January 10th 07 11:17 PM
Ground effect effectiveness Tony Piloting 20 January 10th 07 11:17 PM
Low approaches in ground effect CV Soaring 28 October 21st 04 10:05 PM
Weather and ground effect Kevin Chandler Piloting 12 April 23rd 04 05:01 AM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
