Converting engine from Turbo to non-Turbo
Old October 29th 03, 04:33 PM
Dick Kurtz
Default Converting engine from Turbo to non-Turbo
looking at potential powerplants for my project I have come across a
TSIO- 520 that is mid time,
I am looking for an IO-520,
What exactly does it take to convert an engine to non-turbo? Do
higher compression pistons need to be installed? What of the
injection system? Anyone out there a powerplant mechanic who knows
his way around this issue???
Thanks in advance
Dick
Old October 30th 03, 06:47 AM
On Wed, 29 Oct 2003 19:27:04 GMT, Roger Halstead
:On 29 Oct 2003 07:33:14 -0800, (Dick Kurtz)
:wrote:
:looking at potential powerplants for my project I have come across a
:TSIO- 520 that is mid time,
:I am looking for an IO-520,
:What exactly does it take to convert an engine to non-turbo? Do
:higher compression pistons need to be installed? What of the
:injection system? Anyone out there a powerplant mechanic who knows
:his way around this issue???
:First, I'm not a mechanic, but having a IO540 that was turboed at one
:time...it will take a new set of high compression pistons along with
:rings and a hone job.
:The injectors are different, but "as_I_recall" you could use the
:injectors from the turbo. They are pressurized when used with the
:turbo.
:There's bound to be some one on here who knows the details.
The answer is simple - yes and no.
I don't know all the versions of the TSIO-520, so it depends on
whether it's turbo-supercharged or turbo-normalized. If, for example,
you're looking at the TSIO-520D off the V35TC Bonanza, it's
turbo-supercharged, and runs over 29" MP for full hp. It's
compression ratio is 7.5:1, and it makes 285 hp. The non-turbo
IO-520A makes the same 285 HP with 8.5:1 pistons.
There may be turbo normalized 520's - I don't know of any, but there
may be - that only run 29" MP maximum, and use the turbo to maintain
their hp to critical altitude. If that's what you're looking at,
unbolt the turbo and go fly. OTOH, 7.5:1 is a perfectly reasonable
compression ratio. If you were to unbolt the turbo from the 520D,
you'd give up some hp, but not that much. The O-320 A2B runs 7:1 at
150 hp, the B2C runs 8.5:1 at 160 hp.
If you do decide to increase the compression, Roger is right, it will
take new pistons, new rings and a hone.
You can certainly use turbo fuel injector nozzels unpressurized.
BTW, I probably won't be around much over the next few months, it
looks like I have a house to rebuild. If anyone knows of a good Cozy
project, I'm in the market, I haven't seen what's left of mine but
probably not much.
Old October 30th 03, 10:43 PM
Morgans
wrote in message ...
:turbo.
probably not much.
Did I miss something? Did the fires get you?
Old October 31st 03, 02:21 AM
On Thu, 30 Oct 2003 16:43:12 -0500, "Morgans"
: On Wed, 29 Oct 2003 19:27:04 GMT, Roger Halstead
: wrote:
: :On 29 Oct 2003 07:33:14 -0800, (Dick Kurtz)
: :wrote:
: :looking at potential powerplants for my project I have come across a
: :TSIO- 520 that is mid time,
: :I am looking for an IO-520,
: :What exactly does it take to convert an engine to non-turbo? Do
: :higher compression pistons need to be installed? What of the
: :injection system? Anyone out there a powerplant mechanic who knows
: :his way around this issue???
: :First, I'm not a mechanic, but having a IO540 that was turboed at one
: :time...it will take a new set of high compression pistons along with
: :rings and a hone job.
: :The injectors are different, but "as_I_recall" you could use the
: :injectors from the turbo. They are pressurized when used with the
: :turbo.
: :There's bound to be some one on here who knows the details.
: The answer is simple - yes and no.
: I don't know all the versions of the TSIO-520, so it depends on
: whether it's turbo-supercharged or turbo-normalized. If, for example,
: you're looking at the TSIO-520D off the V35TC Bonanza, it's
: turbo-supercharged, and runs over 29" MP for full hp. It's
: compression ratio is 7.5:1, and it makes 285 hp. The non-turbo
: IO-520A makes the same 285 HP with 8.5:1 pistons.
: There may be turbo normalized 520's - I don't know of any, but there
: may be - that only run 29" MP maximum, and use the turbo to maintain
: their hp to critical altitude. If that's what you're looking at,
: unbolt the turbo and go fly. OTOH, 7.5:1 is a perfectly reasonable
: compression ratio. If you were to unbolt the turbo from the 520D,
: you'd give up some hp, but not that much. The O-320 A2B runs 7:1 at
: 150 hp, the B2C runs 8.5:1 at 160 hp.
: If you do decide to increase the compression, Roger is right, it will
: take new pistons, new rings and a hone.
: You can certainly use turbo fuel injector nozzels unpressurized.
: BTW, I probably won't be around much over the next few months, it
: looks like I have a house to rebuild. If anyone knows of a good Cozy
: project, I'm in the market, I haven't seen what's left of mine but
: probably not much.
Don't know yet. It got my neighborhood, but they haven't let us back
in, if the weather holds they'll probably allow it tomorrow. But it
doesn't look good - the voice mail picks up on the first ring, instead
of the 4th, so the phone's probably been melted.
Old October 31st 03, 03:34 AM
Del Rawlins
On 30 Oct 2003 04:21 PM, posted the following:
Is it possible the power might be out? Good luck.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old October 31st 03, 05:20 AM
On 31 Oct 2003 02:34:27 GMT, Del Rawlins
:On 30 Oct 2003 04:21 PM, posted the following:
: Don't know yet. It got my neighborhood, but they haven't let us back
: in, if the weather holds they'll probably allow it tomorrow. But it
: doesn't look good - the voice mail picks up on the first ring, instead
: of the 4th, so the phone's probably been melted.
:Is it possible the power might be out? Good luck.
No, it's voicemail, not an answering machine. Maybe if the phone
lines are down. But I just called my wife's cell phone, which she
*thinks* she left on, and it does the same thing.
We'll find out tomorrow. If the place is gone it's all right, we're
all fine and everything is insured. It's just a house.
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 05:46 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 01:04 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 09:53 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 09:06 AM
