NACA profile calculations
Old December 6th 09, 05:16 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default NACA profile calculations
I have got into plotting NACA profiles by computing. Humbly beginning
with the simplest, which I presume to be NACA 4-digit, I found the
Wikipedia page as a prime source of information.
Plotting a symmetrical profile is not that hard: at regular intervals
(=X along the chord), one calculates the thickness (=2*Y) and plots a
dot at X,+Y and another at X,-Y . The formula for the thickness is
netaly given in the wikipedia page, neat!
The first step of assymetrical is just as easy: draw the camber line by
calculating its offset from the chord at regular intervals. From the
camber line. intrados and extrados points are again a vector away; and
the magnitude of the vector is calculated in the same way. What beats me
however is that, if I interpret the wikipedia page correctly, this
vector should be considerd perpendicular to the camber line, where I
would expect it to be vertical, i.e. perpendicular to the chord.
Any comments here?
Is my understanding of the wikipedia page correct?
If so, what's a useable algorithm to plt intrados and extrados?
And also, less poignant but still:
How do I calculate from the basic parameters the behaviour of the
profile, i.e. the Cl curves? And perhaps other nice info like the
leading edge diameter?
Generally: any pointers to in-depth information that a non-engineer can
mentally digest?
TIA,
Old December 7th 09, 08:40 AM posted to rec.aviation.homebuilt
Oliver Arend
http://en.wikipedia.org/wiki/NACA_ai...t_NACA_airfoil
dy_c/dx you can get by differentiating between two arbitrarily chosen
points on the camber line. You'll probably need closer spacing of
these points near the leading edge.
How do I calculate from the basic parameters the behaviour of the profile, i.e. the Cl curves?
What are you looking for? Slope will be very close to 2 pi ;-) The
angle of attack of zero lift is -2 f/t (f/t is maximum camber relative
to chord). The cm is more difficult to estimate -- it's easiest to
just plug the airfoil into XFOIL and do the calculation (or do you
prefer
http://www.iag.uni-stuttgart.de/IAG/...lettheorie.pdf
?). The rest, like clmax, are viscous effects and can't simply be
deducted/estimated from the basic parameters.
And perhaps other nice info like the leading edge diameter?
For NACA 4-digit-series, see the Wikipedia page.
Generally: any pointers to in-depth information that a non-engineer can mentally digest?
We would need more information on what you are actually looking for.
It could be structural properties of the airfoil (which XFOIL can
handle as well ;-).
Oliver
Old December 7th 09, 05:30 PM posted to rec.aviation.homebuilt
So weit war ich ja schon...*
**Bis hier bin ich auch noch dabei!
The angle of attack of zero lift is -2 f/t (f/t is maximum camber relative
XFOIL muss es sein was mir fehlte!***
(or do you prefer
Mm, mal schauen, nur nicht gerade jetzt.****
Schade*****
Oliver, besten dank!
KA
* Nothing new there
** This also was more or less mastered before
*** This must be what I was missing
**** Will have a look, not right now though
***** Too bad.
Old December 7th 09, 12:24 PM posted to rec.aviation.homebuilt
Brian Whatcott
jan olieslagers wrote:
/snip/
mentally digest?
TIA,
I think you would be best served by a 2-D flow visualizer of which there
are several out there. I don't think hand computation of reasonable
values for lift n drag are reasonable objectives.
Brian W
Old December 7th 09, 05:37 PM posted to rec.aviation.homebuilt
/snip/
TIA,
Hand computing wasn't really my idea. I've some nice machines down here
called computers. In today's world of office productivity it is lightly
overlooked, still there it is: computers are cheap and plenty today -
and computation is what they were originally meant for. I do mean to
apply this mechanical computation to describe and plot airfoils.
As for the flow visualisers: I'll be grateful for a suggestion of one I
can run from the Linux command line.
Thanks again,
KA
Old December 7th 09, 09:02 PM posted to rec.aviation.homebuilt
On Dec 7, 10:37*am, jan olieslagers
Thanks again,
KA
http://www.mh-aerotools.de/airfoils/javafoil.htm ?
Old December 8th 09, 12:00 AM posted to rec.aviation.homebuilt
Brian Whatcott
/snip/
there are several out there. I don't think hand computation of
reasonable values for lift n drag are reasonable objectives.
/snip/
Thanks again,
KA
I tried an early version of Drela's Xfoil. It is available now in
several suitable flavors he
http://web.mit.edu/drela/Public/web/xfoil/
Can't remember whether these distributions include the data for the many
foils held by U.Illinois. Probably do?
Brian W
Old December 8th 09, 05:28 AM posted to rec.aviation.homebuilt
Thank you, XFOIL had already been mentioned by Oliver too. I will first
explore the Java program mentuioned by Leon@caspercity, it seems to come
close to my natural habitat.
Old December 8th 09, 08:45 AM posted to rec.aviation.homebuilt
Oliver Arend
I was not aware that anyone on this group might never have heard of
XFOIL ;-)
Airfoil coordinates, more than you can handle, are he
http://www.ae.uiuc.edu/m-selig/ads/coord_database.html
Some of the files are in XFOIL format (1 line with name, the rest
coordinates from the trailing edge over extrados, leading edge and
intrados back to the trailing edge), some are in Eppler format (1 line
with name, 1 line with number of coordinates, coordinates for extrados
from LE to TE, coordinates for intrados).
Enjoy!
Oliver
Old December 7th 09, 10:21 PM posted to rec.aviation.homebuilt
Jim Logajan
mentally digest?
Have you checked out some of the links at CFD Online:
http://www.cfd-online.com/
In particular, they have links to various software around the web:
http://www.cfd-online.com/Links/
Calculations for Flying javawizard Piloting 11 October 18th 07 05:22 PM
NACA Numbers??? c hinds Home Built 3 October 11th 04 09:40 PM
NACA Chord Balance point [email protected] Rotorcraft 3 April 27th 04 06:05 AM
Reverse NACA duct Chris W Home Built 22 October 28th 03 10:59 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
