Helicopter gun at LONG range
Old August 13th 03, 07:34 AM
Tony Williams
Default Helicopter gun at LONG range
"Charles Talleyrand" wrote in message ...
Has anyone used a helicopter cannon at LONG standoff range. By long range I mean
a range where the gun must shoot significantly above the straight line to the target
rather like a howitzer.
My vision is a helicopter standing off for safety and firing at an area. I'm assuming
if an AH-64 unloaded it's magazine at me from 10 miles away I would experience
a hail of shells all around me that would chew up every soft target including
any anti-air batteries.
It would take some sensor to measure range accurately (laser rangefinder) and some
software to compute tragetories, but these things need not be heavy or very expensive.
Has anyone ever even experimented or studied such an idea?
The ultimate range limitation given current helicopter installations
would be the maximum elevation permitted by the turret. The AH-64's
gun is limited to only 11 degrees (the French THL turret manages up to
30 degrees, the AH-1's M197 20 degrees).
The ballistic charactistics of the projectiles is also an issue. At
extreme range short aircraft cannon shells like the western 20mm and
30mm may lose stability and start tumbling. The Russian 30mm is much
better; the shells are much heavier and will carry further, but their
mountings don't have the elevation.
Then there's the stability of a helicopter as a gun platform. I
suspect that dispersion at long range would be considerable.
All-in-all, probably a non-starter for any practical purposes.
Tony Williams
Military gun and ammunition website: http://www.quarry.nildram.co.uk
Discussion forum at: http://forums.delphiforums.com/autogun/messages/
Old August 14th 03, 06:08 AM
Charles Talleyrand
"Tony Williams" wrote in message m...
Hmm. Good point. A new helicopter might have different limits, but we'll
be using the existing fleet for a long time.
I don't know enough to understand this. Is tumbling bad? I understood for
something like a personal rifle it was a good thing in that it maximzed damage.
Sure. But if it's good enough at 1000 meters to hit a truck, then at 10,000
meters it should hit an area with a diameter of 10 trucks. That's a small
area given enough rounds on target. Of course I'm going beyond my area of
expertise here.
Tony Williams
Old August 14th 03, 02:10 PM
Thomas Schoene
understood for something like a personal rifle it was a good
A round that tumbles in flight is bad. Some Small arms rounds tumble when
they enter flesh, which increases their wounding potential. But if this
happens before hitting a target, the rounds are liable to go anywhere but
where you aim them. If they do hit something, they will have very poor
penetration.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old August 20th 03, 03:14 AM
Tiger
First the gun can't shoot 10 miles. Second, You can't tell friend of foe from that far
out. If you want to reach out an touch some one, you call on a fire mission. Not a
Apache, wasting ammo.
Long range Wx Paul kgyy Instrument Flight Rules 4 December 31st 04 05:25 PM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 05:20 AM
Does China have long range bombers? Mike Military Aviation 10 May 24th 04 03:16 AM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 11:05 PM
Helicopter gun at LONG range Gordon Military Aviation 17 August 20th 03 03:14 AM
