Non-discrete transponder codes for gliders
Old January 3rd 10, 02:17 AM posted to rec.aviation.soaring
zulu
Default Non-discrete transponder codes for gliders
Rumor has (had), it that the Feds were about to authorize a nation
wide non-discrete transponder code for gliders which was to be 0000 in
lieu of the current VFR squawk of 1200. Does anyone know anything
about this or is this just another pipe dream?
Zulu
Old January 3rd 10, 03:00 AM posted to rec.aviation.soaring
Jim Logajan
Sounds like NTSB recommendation A-08-12 that they sent to the FAA in this
letter:
http://www.ntsb.gov/Recs/letters/2008/A08_10_13.pdf
The NTSB sent another letter at the same time to SSA:
http://www.ntsb.gov/Recs/letters/2008/A08_14_15.pdf
Likely the FAA will issue a notice of proposed rule making if it decides to
ever follow up on A-08-12. Don't know how the coming ADS-B regs change the
playfield with respect to gliders.
Old January 3rd 10, 04:10 AM posted to rec.aviation.soaring
Frank Whiteley
lieu of the current VFR squawk of 1200. *Does anyone know anything
letter:http://www.ntsb.gov/Recs/letters/2008/A08_10_13.pdf
The NTSB sent another letter at the same time to SSA:http://www.ntsb.gov/Recs/letters/2008/A08_14_15.pdf
If done, it will be as a 'document change' rather than formal NPRM. I
don't know the current status, but if it's still moving ahead, target
date is about five weeks.
Frank Whiteley
(USA) NTSB issues recommendations to the FAA and the SSA regarding transponder use in gliders BT Soaring 78 July 25th 08 06:26 PM
(USA) NTSB issues recommendations to the FAA and the SSAregarding transponder use in gliders Andy[_1_] Soaring 4 May 22nd 08 05:16 PM
Glider specific transponder codes Bob Caldwell Soaring 12 January 1st 07 05:18 AM
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 01:15 PM
transponder codes Guy Elden Jr. Piloting 1 December 2nd 03 05:21 PM
