Engine Sizing and Selection
Old October 31st 03, 04:43 AM
Toks Desalu
Default Engine Sizing and Selection
I am in process of searching for an engine.....well two engines. I am
looking at approimately 100 to 120 horsepower engine each. I am sure that
most people would strongly recommend a reputed aircraft engines. However, I
do not want to limit myself to it. I wanted to see everything before I can
make my decision. Of course, the lighter the engine is, the better. Please
feel free to suggest anything to me. I think I just completed my research on
reputed aircraft engines. I might miss something, so don't hesitate to
mention anything that I might miss. I am currently looking and studying the
rotary engines. Any input about it? Any website about it? Is there any
converted auto engines with horsepower that I am looking for? I will get
into auto research later on, but feel free to talk about it. I will keep all
the posts to my hard drive. Anything related to engines, you better speak
out!!!!!
Toks Desalu
PP-SEL
Dyin' to fly!
Old October 31st 03, 05:03 AM
Take a look at the BMW R1100S conversion, there are hundreds running
in Europe made by a German company called Takeoff Gmbh. Takeoff will
sell you just the redrive or the entire engine and exhaust, ready to
bolt on. The complete engine is about $8000, is rated at 100
horsepower, and uses a brand new BMW engine with dual ignition, etc.
That's a heck of an alternative to an O-200 when you consider that it
is 20 lbs lighter and includes Motronic engine management. The
Takeoff parts are beautiful. This is much more than bolting a Rotax C
gearbox on a motorcycle engine. What I want to do is take that engine
and put an RB RAcing turbo system on it. Balancing fuel requirements
and the strength of the gearbox, 115-120 horsepower is about all I can
ask for without adding supplemental fuel, but the RB turbo system will
maintain that power all the way to 30,000 feet with the help of an HKS
boost controller.
On Fri, 31 Oct 2003 04:43:52 GMT, "Toks Desalu"
:I am in process of searching for an engine.....well two engines. I am
:looking at approimately 100 to 120 horsepower engine each. I am sure that
:most people would strongly recommend a reputed aircraft engines. However, I
:do not want to limit myself to it. I wanted to see everything before I can
:make my decision. Of course, the lighter the engine is, the better. Please
:feel free to suggest anything to me. I think I just completed my research on
:reputed aircraft engines. I might miss something, so don't hesitate to
:mention anything that I might miss. I am currently looking and studying the
:rotary engines. Any input about it? Any website about it? Is there any
:converted auto engines with horsepower that I am looking for? I will get
:into auto research later on, but feel free to talk about it. I will keep all
:the posts to my hard drive. Anything related to engines, you better speak
ut!!!!!
:Toks Desalu
:PP-SEL
yin' to fly!
Old October 31st 03, 07:46 PM
Paul Lee
Jabiru makes a 120hp aircraft engine - Jabiru 3300A - $13,000 brand new.
http://www.usjabiru.com/
It includes accessories: Starter, Exhaust, Ram Air Ducts,
Voltage Regulator, Oil Cooler, Alternator, Voltage Regulator, Rubber Mount
Bushings, Prop Guides, Mounting Hardware.
"Toks Desalu" wrote in message news:cMlob.52374$ao4.144039@attbi_s51...
out!!!!!
Toks Desalu
PP-SEL
Dyin' to fly!
Old November 1st 03, 01:41 AM
AlwaysLearning
Before you look into the many auto and motorcycle conversions, with
their "shell game" of horsepower claims, take a look into a couple of
certified aircraft engines you can buy for similar costs, with much
greater simplicity and ease of installation. I'm assuming you're in
Europe, so my two choices there would be a)PZL Franklin O-235, and
b)Moravia LOM inline, (I forget the designation.) Both engines have
been around forever, and you can buy a factory remanufactured engine
in either one for under 10K, unless prices have gone up, lately. And
both engines have accessories, engine mounts, etc., that were
designed, or can be easily fabricated/duplicated from a certified
aircraft.
Old November 1st 03, 04:10 AM
Toks Desalu
Nah-
I am in good ol' America!
Toks
Old November 3rd 03, 06:31 AM
Rob Turk
news:mnGob.73419$HS4.639796@attbi_s01...
Nah-
Toks
If you don't mind using engines from good ol' down under, then Jabiru is an
excellent choise. 120HP at 83Kg (~170lbs), well constructed and well
supported by two very active dealers in the US. Check out the Jabiru engines
forum on http://groups.yahoo.com to learn more about real-life experiences
with these.
Rob
Old October 31st 03, 10:03 PM
Jay
Since you are using 2 engines, you are in a different position from
the typical experimental aero application as far as the reliability of
each individual componant, and the composite reliability of the system
as a whole. You haven't shared the particular engine configuration
you're planning (e.g. push-pull vs. left right) but the use of two
engines brings additional challenges and opportunities.
Opportunities:
Single ignition motors
Operation at high average outputs
Use of 2 stroke power plants.
Since you have 2 engines, you essentially have redundant everything,
completely decoupled. Real about my twin engine pitch at:
http://inline_twin.tripod.com/concept.html
There are very high output 2 stroke motors available around 1hp/lb.
Mainly adapted from snow mobile (Rotax) applications. Used as a
single, the realibility is below what most people desire, but as a
pair, its down right usuable.
Please share your engine configuration with the group.
Rotary- IMHO great possibilites, sports car engine- high power/weight
ratio for a conversion, fail soft operation (will not seize), 2
plugs/cylinder by default.
