Insurance for D Registered
Old January 16th 10, 06:03 PM posted to rec.aviation.soaring
glider[_2_]
Default Insurance for D Registered
Can a "D" registered sailplane get insurance from American company in
USA?
German Insurance will insure a sailplane in every country.....except
in USA.
GA
Old January 16th 10, 09:12 PM posted to rec.aviation.soaring
bildan
On Jan 16, 11:03*am, glider wrote:
*Can a "D" registered sailplane get insurance from American company in
USA?
*German Insurance will insure a sailplane in every country.....except
in USA.
*GA
Check with the German pilots flying their German "D" registered
gliders with the White Sands Soaring Association in Alamogordo, NM.
They must have solved the problem.
Old January 17th 10, 02:50 PM posted to rec.aviation.soaring
GM
USA?
in USA.
*GA
Hi glider,
the short answer is: No!
If your glider is registered in Germany, no US insurance company will
write you a policy. I had buy a policy in Germany for my D-registered
Libelle. Some carriers offer policies for this situation. It may be
much less expensive to register the glider in the US - if your
immigration status allows you to do that; you have to be a permanent
resident alien - and then re-register it in Germany, if/when you
return.
Uli
Old January 17th 10, 04:21 PM posted to rec.aviation.soaring
Brian Whatcott
GM wrote:
/snip/ It may be
resident alien ....
Uli
Actually, you have to be a US citizen or a US entity such as a
corporation to register an aircraft with the FAA.
Brian W
Old January 18th 10, 12:40 AM posted to rec.aviation.soaring
Andy[_1_]
Brian W
Sorry, you are wrong! A resident alien can register an aircraft in
USA. Been there, done that (twice), and have the papers to prove it.
The only wrinkle is that a resident alien cannot be a joint registered
owner, only a sole registered owner.
Andy (just visiting)
Old January 18th 10, 04:47 AM posted to rec.aviation.soaring
GM
On Jan 17, 11:21*am, brian whatcott wrote:
GM wrote:
/snip/ *It may be
resident alien ....
Uli
Brian W
Brian - nope! Please do your homework. The application for
registration asks for the I-151 number, which is the so-called 'Green-
Card' (which is actually not green).
GM
Old January 18th 10, 06:56 PM posted to rec.aviation.soaring
Brian Whatcott
GM wrote:
On Jan 17, 11:21 am, brian whatcott wrote:
GM wrote:
/snip/ It may be
resident alien ....
Uli
Brian W
GM
Hehe....when *I* tried to register an airplane as a resident alien, I
soon found that (for powered aircraft at least) it was necessary to be a
US citizen or US entity. It was not onerous to set up a US corporation
for the purpose at the time.
It is entirely possible that FAA registration rules have relaxed in the
intervening 25 years, but it is also possible that someone else needs to
do a little more homework?? :-)
Brian W
Old January 18th 10, 06:25 PM posted to rec.aviation.soaring
Thorsten
USA?
in USA.
*GA
I currently operate two D-registered gliders in California with a
German insurance. You are right, normally foreign insurance companies
do not want to get into the business of insuring gliders over here due
to the high liability risks. However, I found liability coverage for
both gliders (with higher premiums and lower coverage of course :-) )
through the Zurich insurance in Germany. I can send you some further
details if you are interested.
UK planning to evict N-registered aircraft Juan Jimenez General Aviation 46 September 1st 05 08:04 AM
UK planning to evict N-registered aircraft Juan Jimenez Owning 37 September 1st 05 08:04 AM
UK planning to evict N-registered aircraft George Patterson General Aviation 25 August 12th 05 11:26 PM
UK planning to evict N-registered aircraft George Patterson Owning 27 August 12th 05 11:26 PM
Canadian registered airplanes l.m.bond Owning 3 February 6th 04 11:57 AM
