I have been waiting for the SN-10 USB "stick" to come out and it came
just in time for Santa to stuff it in old JJ's sock. Installation was straight forward, but when I tried to enter the latest software (2.34) using the stick, it wouldn't take it. Paul Remde answered my e-mail right away and indicated I would have to enter it the old way using the DB-9 cable, then future software changes could be uploaded using the stick. He was right and it took 2.34, but when I tried to change the soaring site I got an error message "this stick is using too much power, try another one". I replaced the Verbatim 4GB stick with a Toshiba 4GB. and it worked as advertised. Next I installed the Garmin 16X GPC to drive my SN-10. Garmin didn't provide the mounting screws and the lay-out template wasn't full scale, so I couldn't use it to make a hole template. Made my own punching through a sheet of paper held over the mounting surface. When I turned it on, nothing happened! Another e-mail to Paul and he said I must hook the remote on/off wire to ground if I wasn't turning on the GPS through the SN-10. I soldered the yellow wire to ground and the GPS cranked right up. It doesn't have an indicator light as in the model 20, but the GPS page on the SN-10 shows (no power, searching, tracking) This "stick" setup is soooooo much better than the old system where you had to download a new site, move the file, change the name, take your lap-top to the sailplane, plug it in, open an umbrella so's you could read the screen.........................then do it all again when down-loading the flight! Both good products, well worth the price, $295 for USB and $110 for GPS. Cheers, JJ |
On Jan 20, 5:14*pm, JJ Sinclair wrote:
I have been waiting for the SN-10 USB "stick" to come out and it came just in time for Santa to stuff it in old JJ's sock. Installation was straight forward, but when I tried to enter the latest software (2.34) using the stick, it wouldn't take it. Paul Remde answered my e-mail right away and indicated I would have to enter it the old way using the DB-9 cable, then future software changes could be uploaded using the stick. He was right and it took 2.34, but when I tried to change the soaring site I got an error message "this stick is using too much power, try another one". I replaced the Verbatim 4GB stick with a Toshiba 4GB. and it worked as advertised. Next I installed the Garmin 16X GPC to drive my SN-10. Garmin didn't provide the mounting screws and the lay-out template wasn't full scale, so I couldn't use it to make a hole template. Made my own punching through a sheet of paper held over the mounting surface. When I turned it on, nothing happened! Another e-mail to Paul and he said I must hook the remote on/off wire to ground if I wasn't turning on the GPS through the SN-10. I soldered the yellow wire to ground and the GPS cranked right up. It doesn't have an indicator light as in the model 20, but the GPS page on the SN-10 shows (no power, searching, tracking) This "stick" setup is soooooo much better than the old system where you had to download a new site, move the file, change the name, take your lap-top to the sailplane, plug it in, open an umbrella so's you could read the screen.........................then do it all again when down-loading the flight! Both good products, well worth the price, $295 *for USB and $110 for GPS. Cheers, JJ Thanks JJ ! I don't know what is up with the upgrade not working the first time from the stick. Probably because the stick is junk and taking too much power. Can I have it ? I don't have a test stick that draws excessive power ! See you in Little Rock ? All the best for 2010, Best Regards, Dave PS: I make the GPS (& etc) mounting templates using paper and rubbing over the holes with pencil - makes a good clear pattern (kinda like a gravestone rubbing) - easy to drill. |
When I turned everything on I got bad redio interference on 123.3,
123.5 and 122.8. Just about drove me nuts looking for the source, turned both GPS's off.........no change, turned the SN-10 off and the interference went away. Started grounding things and moving wires and then I thought, what has changed? The USB adaptoter was added, so I plugged in a stick and the interference got worse! I had located the USB adapter within an inch of the radio antenna cable (RGU-58) where it exited the instrument panel.....................moved it away and the interference went away! Recommend you place the USB adapter a good 4" away from rour radio antenna cable. Cheers, JJ |
Sell:Brass Male Adapter,Swivel Female Adapter,Flare Adapter,Tee,Connector,Barbed Tee,Elbow,, | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
Garmin 496 Review | Mike Granby | Piloting | 14 | August 3rd 06 02:42 AM |
Garmin 496 Review | Mike Granby | Owning | 14 | August 3rd 06 02:42 AM |
FA: Garmin GTX-320/327 Narco tray adapter | Scott Skylane | Aviation Marketplace | 0 | March 15th 05 07:49 PM |
AOPA Pilot Product Review | Dean Wilkinson | Products | 0 | July 2nd 04 03:26 PM |
