Compass Correction Card
Old January 22nd 10, 11:03 PM posted to rec.aviation.soaring
glider[_2_]
Default Compass Correction Card
Just for fun......
A long time ago, I was told that a compass correction card is
required.
I was also told it didn't have to be filled out.
That may not be a good idea.
No need to upset our FAA friends.
GA
Old January 23rd 10, 12:14 AM posted to rec.aviation.soaring
lanebush
I believe AC 43.13B can give you a little guidance on that matter.
AC 43.13-1B lists several instances when a compass swing must be
performed. These include:
Whenever the accuracy of the compass is suspected
After a cockpit modification or major replacement involving ferrous
metal
Whenever a compass has been subjected to a shock; for example, after a
hard landing or turbulence
After aircraft has passed through a severe electrical storm
After a lightning strike
Whenever a change is made to the electrical system
Whenever a change of cargo is likely to affect the compass
After an aircraft has been parked on one heading for more than a year
When flux valves are replaced.
An often overlooked matter amongst us aviation technicians.
Lane
Old January 23rd 10, 12:40 AM posted to rec.aviation.soaring
On Jan 22, 6:03*pm, glider wrote:
Just for fun......
* A long time ago, I was told that a compass correction card is
required.
* I was also told it didn't have to be filled out.
* That may not be a good idea.
* No need to upset our FAA friends.
* GA
If compass is perfect, I've been told by my IA, no correction card is
required.
Find a fed that will buy that!
UH
Old January 23rd 10, 03:04 AM posted to rec.aviation.soaring
Morgans[_2_]
required.
Prolly' wouldn't. Just put all zeros on a correction card.
Old January 23rd 10, 03:27 AM posted to rec.aviation.soaring
Andy[_1_]
On Jan 22, 8:04*pm, "Morgans" wrote:
required.
Prolly' wouldn't. *Just put all zeros on a correction card.
I think you are all missing the point.
If no compass is required there cannot be a requirement for a
correction card.
Andy
Old January 23rd 10, 04:07 AM posted to rec.aviation.soaring
Andy[_1_]
correction card.
Andy
In the world of Federal Aviation Regulations the compass is called a
"magnetic direction indicator" and the compass correction card is a
"placard". Try a search of all the regulations (www.landings.com) and
try to find one regulation related to the installation of a magnetic
direction indicator in a "glider" or an "aircraft" - I found none!
All the regulatory requirements are specific to airplanes, rotorcraft,
or certain airships.
Anyone who finds one related to gliders please let me know. Otherwise
celebrate your freedom by burning your correction cards.
Andy
Old January 23rd 10, 02:32 PM posted to rec.aviation.soaring
jcarlyle
At least for my LS8-18, the feds can get you another way - a compass
is on the Minimum Equipment List. So my glider is required to have a
"magnetic direction indicator". The jury is still out on a correction
card, though...
-John
Andy
Old January 23rd 10, 07:37 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Fri, 22 Jan 2010 19:27:47 -0800 (PST), Andy
required.
correction card.
Wouldn't be too sure about that. I believe a non-required instrument
which is not functioning properly (which might well include an
uncorrected compass) must be covered up or removed. A power club I
once belonged to ran into that, being forced to remove a failed DG
from a VFR-only airplane.
rj
Vertical card compass? Bubba[_2_] Home Built 1 March 31st 07 12:49 AM
Vertical Card Compass? Bubba[_2_] Products 0 March 30th 07 06:58 PM
Vertical Card Compass Bubba[_2_] General Aviation 0 March 30th 07 06:56 PM
Vertical Card Compass? Bubba[_2_] Aviation Marketplace 0 March 30th 07 06:56 PM
Airpath C2400 compass correction card template ? [email protected] Soaring 4 March 9th 07 06:55 PM
