Is there a version of XCSoar that is compatible with the Compaq Aero
1550 (MIPS R4111, CE 3.0). Is so, is it available for download? I have downloaded Installxcsoar-ppc2002.exe. It installs ok but returns the error "not a valid Windows CE application" when atempting to run it. Don't want to waste any more time on this if it isn't supported anymore. thanks Andy |
For anyone still using the 1550 I am set up to compile the exe file
for it. Let me know if you want me to email you a newer exe file for the 1550. Brian |
On Jan 23, 1:02*pm, Brian wrote:
For anyone still using the 1550 I am set up to compile the exe file for it. Let me know if you want me to email you a newer exe file for the 1550. Brian Thanks Wayne and Brian for the help. Andy |
Andy,
So how does XC run on the 1550? How did it install? John Seaborn On Jan 23, 2:50*pm, Andy wrote: On Jan 23, 1:02*pm, Brian wrote: For anyone still using the 1550 I am set up to compile the exe file for it. Let me know if you want me to email you a newer exe file for the 1550. Brian Thanks Wayne and Brian for the help. Andy |
On Jan 23, 7:06*pm, John Seaborn wrote:
Andy, So how does XC run on the 1550? How did it install? I received Aero 1550 compatible files for XCSoar and XCSoar simulator. I just copied them to my 1550 using the explorer function of ActiveSync and they run fine. You can use the same TP file as GNII but need Open Air format airspace. You'll also need a suitable polar file. I have not attempted to install any terrain files and have no expectaion it would work on this processor. So far I'm just getting familiar with it in simulator mode and can't comment on how well it will work in flight on this device. I can pass the files on to you if you send me an email. I was not able to find compatible files on the XCSoar site and have been told that support for the 1550 is discontinued. But see Brian's offer above. I found the XCSoar documentation relating to 1550 support to be conflicting and confusing but maybe that's just me. Andy |
What works even better than the Simulator mode is to use the Flight
Version and the Replay feature. Put an IGC file from one of your previous flights on the PDA and replay it. This may work on the Simulator as well, but I don't think I have tried it. Brian |
Think you'd be much happier with an ipaq 3900 series device. Zippy
processor and good, cockpit readable color display. You can get these on ebay inexpensively. You would need a different cradle though. -Evan Ludeman / T8 |
On Jan 24, 1:11*pm, T8 wrote:
Think you'd be much happier with an ipaq *3900 series device. *Zippy processor and good, cockpit readable color display. *You can get these on ebay inexpensively. *You would need a different cradle though. -Evan Ludeman / T8 Actually, I think the iPAQ hx4700 series has the best display; with the "PNA" devices (HP 340 and similar units) just about tied - but with a slightly trickier setup if you need to connect to any external devices (since the PNA devices have no wired connectors). Nice thing is that you can get hx4700 or hx4705 units on eBay for about $120, whereas the PNA units are around $200 - $250. --Noel (who uses an iPAQ hx4700 connected to an ewMicroRecorder with XCSoar) |
| Thread Tools | |
| Display Modes | |
| looking for Compaq Aero 1550 | [email protected] | Soaring | 3 | June 5th 08 06:19 PM |
| WANTED: Compaq Aero 1550 | WaltWX | Soaring | 12 | March 20th 08 05:10 PM |
| FS: Aero 1550 | GH | Soaring | 1 | September 24th 04 03:59 AM |
| FS Aero 1550 | Ed Hollestelle | Soaring | 0 | July 12th 04 09:10 PM |
| mSeeYou (ver1.01) on Aero 1550 | Jean-Paul BERRY | Soaring | 0 | February 20th 04 03:59 PM |
