A-4 / A-7 Question
Old October 8th 03, 04:02 AM
Thomas Schoene
"Tank Fixer" wrote in message
k.net
says...
It almost sounds like the 30mm Caseless Pods that can be mounted
under Fighters making even an A-4 into a tank killer. That died
when the A-7 did. Too bad. The A-7E was a superior AC to the A-10
when armed with the 30mm caseless chain gun. To upgrade the A-7 to
an AC with the F/A-18 perfomance would have cost appr. 3.5 million
per copy. versus how much for an A-10 that requires constant
TopCap? Another Congressional Boondoggle.
Anyone know what he is talking about ?
I've not heard of any system like this before.
I'm guessing he's takling about a couple two things.
First is the GPU-5 (aka Pave Claw) gun pod, which holds a four-barrel
version of the GAU-8 called GAU-13. (Definitely neither caseless nor a
chain gun, though). It was supposed to give conventional fighters almost the
same gun power as the A-10. But it really didn't work very well. The New
York Air Natioanl Guard had one F-16 unit that went to the Gulf with the
GPU-5 in 1991 (the "Boys from Syracuse"/174th Fighter Wing). They took the
pods off the planes early in the proceedings and never flew them again.
http://www.f-16.net/reference/versions/f16_fa.html
Second, for a time, there was discussion of using a modified A-7 with
afterbrning engnie as a CAS bird instead of the A-10. But that was Air
Force, not Navy. And as much a I like the A-7, I have to admit that this
was probably a dead end idea. Even with extensive mods, the A-7 was never
going to be a turning fighter or radar missile shooter like the Hornet.
http://www.vought.com/heritage/products/html/ya-7f.html
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old October 8th 03, 07:28 AM
Tank Fixer
In article et,
lid says...
k.net
says...
Thanks, I had heard of the F16 experiment but never one on the A-4 or A-7
When dealing with propaganda terminology one sometimes always speaks in
variable absolutes. This is not to be mistaken for an unbiased slant.
Old October 10th 03, 05:28 AM
Helomech
"Thomas Schoene" wrote in message
nk.net...
k.net
says...
Howdy,
When I was in the A-4 community we had a 20MM Gau pod (I forget the number)
that could be hung on a station - usually the centerline, and was good for
chewing up pretty much anything - the Navy A-7 Squadrons had them also - I
saw them hang one or two around 1982- 1983 and do some gunnery with them -
rarely though.
I was in MAG-42 Det A at Cecil Field (FLying Gators) we had VA-203 next
door. I don't believe they carried much ammo though - perhaps 500 rounds?
I do know they pretty much sucked - they jammed alot and the Red Shirts
hated them... we had three or four - and they sat in storage.
But I never saw a 30mm pod on any aircraft ever......
Helomech
Old October 8th 03, 06:59 PM
John Carrier
The A-7E was a superior AC to the A-10 when armed with the
30mm caseless chain gun. To upgrade the A-7 to an AC with the F/A-18
perfomance would have cost appr. 3.5 million per copy.
The A-7 could have perhaps gotten F-18 thrust ... that's different in many
respects from F-18 performance.
The A-10 is nicely optimized for the hostile CAS environment with two
well-separated engines, an armor tub for the pilot, etc. It lacks the range
and speed of the A-7, but that's not the prime driver for the mission. You
could also hang a large gun on the F-15E (arguably the best strike fighter
in the business) and kill tanks. That doesn't make it the best CAS
aircraft.
R / John
Old October 9th 03, 11:47 AM
Doug \Woody\ and Erin Beal
On 10/8/03 12:59 PM, in article , "John
aircraft.
R / John
I agree with John. When the need arises for a attack aircraft that can get
low relatively safely and eliminate targets, the A-10 is the most effective
choice.
Don't forget though... CAS has evolved somewhat. If the TACP has the
gadgetry/ability to get a good set of coordinates, there's no need to have
strike fighters even point their noses at the ground. Plinking targets via
level deliveries with JDAM from medium and high altitudes is the way to go
now. As electronically uplinked 9-line briefs come on line and the ability
to generate these coords from the ground proliferates, the need to point
noses at dirt will decrease even more.
Nearly gone are the old days when pilot (or B/N) skill was the most
important targeting skill. Less romanticism, more accuracy.
--Woody
Old October 9th 03, 02:29 PM
Ed Rasimus
On Thu, 09 Oct 2003 10:47:29 GMT, "Doug \"Woody\" and Erin Beal"
aircraft.
R / John
choice.
--Woody
Glad to see the recognition of that. I can't begin to relate the
number of crusty ol' curmudgeons who bewail the loss to the inventory
of naplam and 2.75 FFARs because "we've abandoned CAS". They fail to
recongize the new technology that provides equivalent or better
close-in accuracy from afar. Lots of ol' timers couldn't match the CEP
of JDAM when doing laydown at 100 feet.
Also part of the equation is the changing face of war in which we
aren't seeing fixed battle positions and (hopefully) not encountering
"troops in the wire."
While doing CAS from afar doesn't have the dramatic flair of the good
ol' days, it certainly is just as effective. Won't make very good
footage for some future war movie though.
Old October 9th 03, 03:41 PM
Mike Kanze
All excellent discussion and very good points, but what do our
ground-pounding "customers" think of the effectiveness of current CAS
doctrine?
Mike Kanze
436 Greenbrier Road
Half Moon Bay, California 94019-2259
USA
650-726-7890
"The day the telemarketers pay my phone bill, I'll be happy to give them
their right of free speech."
- Linda Seals
"Ed Rasimus" wrote in message
range
You
fighter
aircraft.
R / John
get
effective
choice.
have
via
go
ability
--Woody
Old October 9th 03, 05:52 PM
John R Weiss
"Mike Kanze" wrote...
doctrine?
I don't know about now, but I do recall one particular conference back in 1989
or so, when we were doing the Dem-Val of AIWS (now JSOW). The USMC rep was
adamant that they could not accept the concept of an autonomous standoff weapon
used for CAS targets in close proximity to friendly Marines. With the
possibility of mistargeting and no means of aborting the weapon, the risk was
too high. With conventional weapons, the FAC had the airplane in sight during
the roll-in and delivery, and had the opportunity to abort the run until just
prior to weapon release.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Speech: A Question of Loyalty: Gen. Billy Mitchell Otis Willie Military Aviation 0 September 25th 04 09:30 PM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
