Twin electrics
Old January 30th 10, 01:42 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default Twin electrics
How does one charge the battery in a twin?
The logical idea seems to have the battery connected to the bus, and
both alternators supplying current (and thus power) to the bus. However
alternators have a regulator, mostly built-in, that regulates the field
so as to produce a constant voltage even if load and rpm vary. But it
would be impossible to have both alternators controlled to produce
exactly the same voltage; and as soon as there is a difference, the
greater part of curent will come from one alternator, causing higher
load and premature wear.
Is this a theoretical concern only? Does one need to install TWO
batteries, with buses normally separated, as apparently is done in (at
least some) biz-jets?
Sorry if the point is moot, or the question silly, I was just wondering.
Not that I'll be be building a twin anywhere soon...
Old January 31st 10, 04:20 AM posted to rec.aviation.homebuilt
Peter Dohm
"jan olieslagers" wrote in message
The logical idea seems to have the battery connected to the bus, and both
alternators have a regulator, mostly built-in, that regulates the field so
as to produce a constant voltage even if load and rpm vary. But it would
be impossible to have both alternators controlled to produce exactly the
same voltage; and as soon as there is a difference, the greater part of
curent will come from one alternator, causing higher load and premature
wear.
The light twins that I've seen, as well as the King Air, use one
battery--even tough is is sometimes a pair of 12 volt batteries stacked in
series to make a single 24 volt battery.
I've been away from that field too long and no longer recall whether you
could find sufficient information in a POH to understand the method used; or
whether you would require a service manual.
Perhaps one of the A&Es on the forum will shed some light.
Peter
Old February 5th 10, 08:45 PM posted to rec.aviation.homebuilt
Default Twin electrics (or is this forum really dead...?)
Thanks for your kind reply, Peter. But I am a bit disappointed in the
silence that followed...
Twin Cub and twin Mustang William Hung[_2_] Piloting 13 February 10th 08 05:05 PM
ID Twin w/ twin vert stabs--RPV? Unk_Twin.jpg (01/01) No Name Aviation Photos 5 October 12th 07 06:55 AM
Wind/Solar Electrics ??? RST Engineering Owning 166 December 31st 05 03:38 AM
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 05:52 AM
Which twin Big D Piloting 15 November 15th 03 06:09 AM
