W&B-Where do you Measure People Positions
Old January 31st 10, 09:14 PM posted to rec.aviation.homebuilt
Paul Dow (Remove CAPS in address)
Default W&B-Where do you Measure People Positions
I'm helping a chapter member do the initial weight measurements on his
plane. I think we have everything except what point should be used for
the seat positions. I didn't see it addressed in the weight and balance
section of AC 43.13.
What point along the seat is considered the center of a sitting person?
I know an inch or two either way won't make a bunch of difference, but
we might as well start with the best number achievable.
Thanks
Old January 31st 10, 09:32 PM posted to rec.aviation.homebuilt
On Jan 31, 2:14*pm, "Paul Dow (Remove CAPS in address)"
Thanks
Use the guy's belt buckle. It's pretty close.
Dan
Old January 31st 10, 09:49 PM posted to rec.aviation.homebuilt
Or you could weigh the aircraft without the pilot. Then with the pilot. Take the difference in the tailwheel weights and multiply it by the distance between the tail wheel and main mounts. Divide the product of the calculation by the pilot's weight. The result will be the distance from the main mount to the pilot seat.
See paragraph B in the W&B calculation near the bottom of the following link:
http://www.soaridaho.com/Schreder/Sc...976_HP-18.html
HP-14 6F
http://www.tinyurl.com/N990-6F
wrote in message ...
On Jan 31, 2:14 pm, "Paul Dow (Remove CAPS in address)"
Thanks
Dan
Old January 31st 10, 11:49 PM posted to rec.aviation.homebuilt
Peter Dohm
"Wayne Paul" wrote in message
m...
link:
HP-14 6F
--------------new post begins---------
Remember to first level the aircraft.
Assuming that it is not an original design, there should be a recomended
datum line specified for that purpose.
(Also, please use the axle positions rather than the undercarriage mounting
positions.)
Peter
Old February 1st 10, 12:41 AM posted to rec.aviation.homebuilt
Thanks for the replies everyone.
The scales were borrowed, so it would be difficult to get them back
again to do the measurements. That procedure makes sense though.
The belt buckle idea seems pretty good. The seats don't have much
recline, so my big butt / fat head should balance each other out.
Paul
Old February 1st 10, 03:02 AM posted to rec.aviation.homebuilt
I had asked another friend this question, and he's a member of our
chapter, and the one in Hartford. Joe Gauthier (EAA Homebuilt Council)
is also a member of the Hartford chapter, and Joe agreed that the belt
buckle method was what should be used if we couldn't use the 'weigh the
pilot while the plane's on the scales' method.
Thanks again.
Paul
Old February 1st 10, 11:11 AM posted to rec.aviation.homebuilt
Stealth Pilot[_4_]
On Sun, 31 Jan 2010 16:14:32 -0500, "Paul Dow (Remove CAPS in
Thanks
anthropomorphically a seated pilots cg is about an inch aft of his
belly button.
as dan says use the location of his belt buckle. you wont detect the
difference.
Stealth Pilot
"Airplanes don't kill people!, people kill people!" Laonork Owning 8 May 21st 12 05:56 AM
Glider Pilots Wanted - Worldwide Positions [email protected] Soaring 15 October 16th 07 01:45 AM
Saving windows positions in FS2004??? jmiguez Simulators 0 May 4th 05 12:34 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 12:04 AM
Air Force to cut 297 positions in Alaska, Hawaii, Guam Otis Willie Military Aviation 0 July 26th 03 09:05 PM
