SOLVED! A Standard Engine for Homebuilders
Old February 3rd 10, 06:01 PM posted to rec.aviation.homebuilt
Veeduber[_3_]
Default SOLVED! A Standard Engine for Homebuilders
To All:
A change in the alloy of the DuraFix aluminum brazing rods now allows
us to install the Fat-Fin modification without fear of having the
extended fins warp or fall off.
See my blog (bobhooversblog) and Groups specific to VW conversions for
more specific information, or contact me directly.
-R.S.Hoover
Old February 3rd 10, 06:15 PM posted to rec.aviation.homebuilt
stol
On Feb 3, 11:01*am, Veeduber wrote:
To All:
-R.S.Hoover
Hi !!!!!!!!!!!!!!!!! good to seeya posting again..... GGG
Old February 4th 10, 08:31 AM posted to rec.aviation.homebuilt
Stealth Pilot[_4_]
On Wed, 3 Feb 2010 10:01:19 -0800 (PST), Veeduber
To All:
-R.S.Hoover
good to see you vertical!
what temperature does the brazing rod weld at and what temperature
does it melt at after it is welded.( I assume that there is a slight
alloy change during the weld)
I've used the zinc alloy brazing rods on aloooominum and the problem I
encountered was that the aloooominum conducted heat so well that when
you got the next joint up to temperature all the others became liquid
at the same time. it was a bugger to keep everything together but it
worked.
Stealth Pilot
Old February 5th 10, 07:37 PM posted to rec.aviation.homebuilt
Peter Dohm
"Veeduber" wrote in message
To All:
-R.S.Hoover
I'm glad to see that you're feeling well enough to post!
Peter
AN ENGINE FOR HOMEBUILDERS Bob Home Built 65 June 5th 09 07:45 PM
Problem solved Don Tabor Piloting 4 December 11th 07 02:40 AM
Is this the place for Homebuilders? Gilan Home Built 2 September 23rd 04 02:06 PM
Mystery Solved Jeff Franks Piloting 4 August 31st 04 05:02 AM
Pan AM 747 mystery solved! Alan White Simulators 1 July 18th 03 06:29 PM
