Antenna questions...
Old February 9th 10, 03:18 PM posted to rec.aviation.homebuilt
bob1234
Default Antenna questions...
....here are your wierd questions of the week that are the result of
several bored people talking about building airplanes:
Can a thin foil tape be fastened to the front of a wooden spar to act
as a VHF antenna? The antenna would be encapsulated in several layers
of epoxy or spar varnish and would not be penetrated by rib nails
(wood ribs) or compression member bolts. The leading edge would be
composed of wood ply.
Can a steel wingtip bow in a rag and wood wing also be used as an
antenna?
Bob1234
Old February 9th 10, 08:57 PM posted to rec.aviation.homebuilt
flybynightkarmarepair
as a VHF antenna? *The antenna would be encapsulated in several layers
(wood ribs) or compression member bolts. *The leading edge would be
Yes, in fact Jim Weir taught Bellanca how to do this on Vikings years
ago. You need a some RF baluns, but the composite antenna kit from
RST engineering has everything you need. You can do VOR antennas too.
antenna?
Probably not very well. It's oriented the wrong way, and tuning it
would be a PITA, if it's possible at all.
Bob1234
Old February 10th 10, 01:06 AM posted to rec.aviation.homebuilt
RST Engineering[_2_]
On Tue, 9 Feb 2010 07:18:59 -0800 (PST), bob1234
We've been doing foil antennas in plastic airplanes for about thirty
years and it seems to work just fine. The only thing you want to
watch out for is keeping relatively large (either in area or length)
pieces of metal away from the outer halves of the antenna "ears".
Things like flying wires and control cables will drive it nuts.
You also need to feed a balanced dipole antenna with a balun (BALanced
to UNbalanced) between the antenna ears and the coax.
antenna?
Sort of. As an antenna for an FM radio it will work just fine.
However, as a tuned antenna, the odds of it being just the right
length are somewhere around the odds of winning an argument with an
FAA inspector.
antenna et Home Built 7 June 29th 08 04:00 PM
GPS Antenna 150flivver Owning 14 December 11th 05 05:38 AM
Antenna questions Steve Ruse Home Built 10 January 27th 05 02:30 AM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) Jim Yanik Military Aviation 2 October 9th 03 09:36 PM
