Remove layer of cloth/Gelcoat
Old February 9th 10, 06:34 PM posted to rec.aviation.soaring
glider[_2_]
Default Remove layer of cloth/Gelcoat
I know it can be done.
On an ASW-15, the first layer of cloth was pulled off the wings and a
fresh layer of cloth was applied. It worked out well. The naked
surface is rough enough to allow good bond of new layer.
GA
Old February 9th 10, 07:39 PM posted to rec.aviation.soaring
*On an ASW-15, the first layer of cloth was pulled off the wings and a
*GA
Schleicher manual mentions this in maintenance instructions- paint
cracks associated with damage that goes thru gelcoat into top layer of
glass.
UH
Gelcoat sag? [email protected] Soaring 10 December 17th 07 08:07 PM
composite using aluminum windowscreen layer Allan Morrison Home Built 4 January 27th 05 01:19 PM
F104- Boundary Layer Control Scet Military Aviation 7 August 27th 04 09:48 AM
Descending through a thin icing layer Wyatt Emmerich Instrument Flight Rules 70 December 31st 03 05:17 AM
Ferro gelcoat Basil Fairston Soaring 0 December 16th 03 08:34 AM
