Shipping glider from Germany to USA
Old February 18th 10, 03:39 PM posted to rec.aviation.soaring
Dan[_6_]
Default Shipping glider from Germany to USA
I'm considering buying a glider in Germany and I've read and heard a
bit about the ins and outs of the process.
I'd like to know what the typical costs are and how long it takes.
Brokers? do I need one or are they really worth using?
Also anyone have experience with licensing an used ex German glider
(currently flying) in Experimental category in US?
Thank in advance,
Dan
Old February 19th 10, 05:32 AM posted to rec.aviation.soaring
Peter[_1_]
On Thu, 18 Feb 2010 07:39:21 -0800, Dan wrote:
I'm considering buying a glider in Germany and I've read and heard a bit
about the ins and outs of the process. I'd like to know what the typical
costs are and how long it takes. Brokers? do I need one or are they
really worth using?
Thank in advance,
Dan
I just got a random quote for a 40ft container from San Franciso (USA) to
Newcastle(UK) (Door to Door), and it came in around $6000, I'm fairly
certain that a conventional Cobra type single seater trailer will fit
without (any)major mods with lots of spare room. I have not looked
seriously at this but took advantage of one of those sites that sends a
request for a shipping quote to multiple vendors... if you can deal with
the spamming you'll get from them all touting their business its easy to
get quotes and they all seem very keen...I'm sure the price can be
negotiated down.
Old February 19th 10, 08:05 AM posted to rec.aviation.soaring
Darryl Ramm
costs are and how long it takes. Brokers? *do I need one or are they
really worth using?
Thank in advance,
Dan
negotiated down.
Why suggest a container? Most gliders travel from Europe to the USA in
their trailers on a roll-on roll-off ship. Sometimes shipping in a
container make sense if you have multiple gliders or other equipment
with it. Single trailer roll-on roll off should be around $2k (very
roughly, depending on where you are going, I have not looked). I think
you will find useful comments in the r.a.s archive on shipping glider
trailers to the USA.
Darryl
Old February 19th 10, 01:21 PM posted to rec.aviation.soaring
soarpilot
really worth using?
Thank in advance,
Dan
negotiated down.
Darryl- Hide quoted text -
- Show quoted text -
You can do it without a broker, there is no law requiring the use of
such although the typical clerk at customs will make you feel you
must. Ask for a manager when you get the broker requirement stated to
you. Make sure your paperwork is meticulous, in order, and you
understand it. The customs manager will be appreciative of this and
very helpful in getting you through if he or she sees you have done
your work.
- I did Roll On - Roll Off last year, UK to US, NJ for about 2300 USD.
Wallenius-Wilhelmsen, they ship from Germany as well. The plane and
trailer came over with a load of new BMWs.
- If the glider is in an enclosed trailer, why in the world would you
pay lofty container fees? If you ship RoRo, make sure your
measurements are correct for the trailer size. Include the trailer
tongue in the length!! Also, have the seller send you pictures of the
trailer, particularly pictures of the trailer's serial number and any
registration numbers, model, etc. It makes customs work lots easier
with pictures. Also, sailplanes and trailers DO NOT incur import
taxes.
- Make sure you get the US Dept of Transportation paperwork done and
you understand how to get the trailer in the US. This surprisingly is
the more difficult part of the process. If the trailer is greater
than 25 years old, it makes things much more simple on the DOT
required forms and processes. It must have a Mfg. DOT letter of
conformity if newer than 25 years old. This has to be a letter from
the manufacturer. One can usually come up with this type letter given
enough reserach and creativity .........
- I imported a Grob Astir CS and had it certificated Experimental.
At first the DSBO told me I could not "willy-nilly" register
Experimental just cause I wanted to. The Grob is type certificated in
the US but I had failed to understand I needed an Export C of A to
register it here as Type Certified. Surprisingly, for no stated
reason, the DSBO allowed me to register the bird experimental. If it
is type certified, just get the Export C of A done and register it
typed here. If not, Experimental airworthiness can be done.
- You can register the plane and get the N-number as it is actually
in transit. Get the bill of sale forwarded to you. Have an N number
reserved, and send in the registration asap. This way, you can have
the airworthiness done as soon as you get off the pier and show the N
number to customs.
- There is a very valuabale web link to use as a guideline for this
process:
http://www.dg-flugzeugbau.de/importing-usa.html. There is a separate
word document for both the saiplane and the trailer. I used it, was
meticulous in my work and had the entire process at customs done in
about an hour, pier delivery less than an hour. REMEMBER ABOUT THE
EXPORT C OF A. It was the one thing this guide did not cover well.
Oh yeah, don't forget to bring wiring materials to rewire your trailer
lights. Your state will be the driving factor in trailer tags, etc.
I am lucky to have done this process, for I feel I saved almost fifty
percent in my purchase price of a 102 compared to what they go for
here in the states- even after absorbing shipping costs in the deal.
the GBP was sucking wind to the USD then, don't know what it looks
like now. It all was VERY WELL worth it to me and my frugality.
Sweat equity, what a glorious thing! Good luck with your venture.
Old February 20th 10, 04:46 AM posted to rec.aviation.soaring
Peter[_1_]
bit about the ins and outs of the process. I'd like to know what the
typical costs are and how long it takes. Brokers? Â*do I need one or
Thank in advance,
Dan
to Newcastle(UK) (Door to Door), and it came in around $6000, I'm
fairly certain that a conventional Cobra type single seater trailer
will fit without (any)major mods with lots of spare room. I have not
looked seriously at this but took advantage of one of those sites that
sends a request for a shipping quote to multiple vendors... if you can
deal with the spamming you'll get from them all touting their business
its easy to get quotes and they all seem very keen...I'm sure the price
can be negotiated down.
Darryl
I was considering moving countries again, and the glider was an
afterthought... a 20ft container was around $4500, and a 40ft one was
$6000 with plenty of room for my stuff as well as a glider... I have not
deeply explored the options... it was just something I looked at on a
whim recently... its just a current data point that might be useful to
others... Ro-Ro sounds better for the glider alone, but thats not what i
was doing.
Old February 20th 10, 01:39 PM posted to rec.aviation.soaring
Papa3
really worth using?
Thank in advance,
Dan
negotiated down.
must. *Ask for a manager when you get the broker requirement stated to
you. *Make sure your paperwork is meticulous, in order, and you
understand it. *The customs manager will be appreciative of this and
your work.
Wallenius-Wilhelmsen, they ship from Germany as well. *The plane and
pay lofty container fees? *If you ship RoRo, make sure your
measurements are correct for the trailer size. *Include the trailer
tongue in the length!! *Also, have the seller send you pictures of the
registration numbers, model, etc. *It makes customs work lots easier
with pictures. *Also, sailplanes and trailers DO NOT incur import
taxes.
you understand how to get the trailer in the US. *This surprisingly is
the more difficult part of the process. *If the trailer is greater
required forms and processes. *It must have a Mfg. DOT letter of
conformity if newer than 25 years old. *This has to be a letter from
the manufacturer. *One can usually come up with this type letter given
- *I imported a Grob Astir CS and had it certificated Experimental.
Experimental just cause I wanted to. *The Grob is type certificated in
register it here as Type Certified. *Surprisingly, for no stated
reason, the DSBO allowed me to register the bird experimental. *If it
typed here. *If not, Experimental airworthiness can be done.
- *You can register the plane and get the N-number as it is actually
in transit. *Get the bill of sale forwarded to you. *Have an N number
reserved, and send in the registration asap. *This way, you can have
number to customs.
process:http://www.dg-flugzeugbau.de/importing-usa.html. There is a separate
about an hour, pier delivery less than an hour. *REMEMBER ABOUT THE
EXPORT C OF A. *It was the one thing this guide did not cover well.
lights. *Your state will be the driving factor in trailer tags, etc.
like now. *It all was VERY WELL worth it to me and my frugality.
Sweat equity, what a glorious thing! *Good luck with your venture.- Hide quoted text -
FWIW, agree with all of the above except the point on the broker. It
really just depends on how you value your time. The broker I used was
a couple of hundered bucks at most, and the hours I would have spent
trying to wade through the regulations just wasn't worth it to me. I
do especially like the comment regarding the trailer that one can
"come up with a [DOT Letter] given enough research and
creativity..."
P3
Shipping a Glider from Europe Coucked Soaring 7 August 21st 15 01:25 PM
Glider shipping to Poland [email protected] Soaring 0 August 6th 09 09:14 PM
Exporting a glider to/import a glider into Germany Pete Smith[_2_] Soaring 1 August 8th 08 09:33 AM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Info on Shipping Glider OUT of USA Ray Lovinggood Soaring 16 November 18th 05 01:57 AM
