iPAQ 310 Backlight Woes
Old February 18th 10, 09:31 PM posted to rec.aviation.soaring
Paul Remde
Default iPAQ 310 Backlight Woes
Hi,
I have been pretty happy with my iPAQ 310 with SeeYou Mobile, but there is
one issue that has been very frustrating. The backlight keeps changing back
to auto-dim mode. I have a customer that is having the same problem. We
can both follow the procedure below to get the backlight to stay on full
power - but it only seems to work for a short time (a few days). It is as
if the settings change back to defaults after power-down or soft resets. I
keep my iPAQ 310 on the charger at all times, so it is not a power issue.
 Open "Backlight Control" and set High backlight (max)
 You don't need to change timeouts in the two upper boxes, because those
values are controlled by "Display Properties".
 Open "Power Properties".
 Power scheme: AC Power
 Set to "Never" all controls.
 Open "Display Properties"
 Select "Backlight" tab
 Select "Automatically turn off backlight while on external power", and set
it to 30 minutes, then exit with Ok.
 Open again "Display Properties"
 DESELECT "Automatically turn off backlight while on external power".
 Exit with Ok.
 Open "Backlight control" again, you will see that "AC power and device is
idle for" box is now EMPTY, correctly. Don't do anything. Press Ok.
I found the procedure above on a web site from one of the XCSoar developers.
Does anyone have a procedure that works and keeps working?
I love the iPAQ 310 except for this one issue.
Paul Remde
Cumulus Soaring, Inc.
Old February 18th 10, 11:48 PM posted to rec.aviation.soaring
Brian Whatcott
Paul Remde wrote:
Hi,
is one issue that has been very frustrating. The backlight keeps
changing back to auto-dim mode. I have a customer that is having the
same problem. We can both follow the procedure below to get the
backlight to stay on full power - but it only seems to work for a short
time (a few days). It is as if the settings change back to defaults
after power-down or soft resets. I keep my iPAQ 310 on the charger at
those values are controlled by "Display Properties".
set it to 30 minutes, then exit with Ok.
 Exit with Ok.
is idle for" box is now EMPTY, correctly. Don't do anything. Press Ok.
developers.
Paul Remde
I have seen something of the same kind on an IQue loaded with APIC.
(And so has an unhappy user of this rig who noticed the same thing and
wrote me privately.)
Not exactly a procedure....
My best guess is a noisy connect/disconnect/reconnect triggering the
problem. In thinking about this - it seems like a super cap across
the DC power path, with a series R or L might cut the crap usefully.
Brian W
Old February 19th 10, 01:07 AM posted to rec.aviation.soaring
Paul Remde
Hi Brian,
Thanks for the thoughts. But the problem is not a hardware issue. It is a
software issue. The unit has a setting for how long until the backlight
turns off when on internal power and another setting for when on external
power. The settings seem to be re-setting by themselves.
Best Regards,
Paul Remde
"brian whatcott" wrote in message
Paul Remde wrote:
Hi,
 Exit with Ok.
developers.
Paul Remde
problem. In thinking about this - it seems like a super cap across the
Brian W
Old February 19th 10, 01:14 AM posted to rec.aviation.soaring
Brad[_2_]
On Feb 18, 5:07*pm, "Paul Remde" wrote:
Hi Brian,
Thanks for the thoughts. *But the problem is not a hardware issue. *It is a
software issue. *The unit has a setting for how long until the backlight
power. *The settings seem to be re-setting by themselves.
Best Regards,
Paul Remde
Paul Remde wrote:
Hi,
is one issue that has been very frustrating. *The backlight keeps
changing back to auto-dim mode. *I have a customer that is having the
same problem. *We can both follow the procedure below to get the
time (a few days). *It is as if the settings change back to defaults
after power-down or soft resets. *I keep my iPAQ 310 on the charger at
 Exit with Ok.
developers.
Paul Remde
problem. * * In thinking about this - it seems like a super cap across the
Brian W
the latest version of XC Soar, LK8000 fixes that, at least for that
flight software. My 310 stays on all night and every day...burning in
the software and unit.
Brad
Old February 19th 10, 11:30 AM posted to rec.aviation.soaring
Andrej Kolar[_3_]
The problem is actually that iPaq 310 reverts to auto-dim each time
the HP road navigation starts. We have fixed that for the future
versions of SeeYou Mobile where we always put the backlight to full
when SeeYou Mobile starts on an HP 310.
Best way to avoid it with 3.12 is to keep the SD Card in the slot all
the time.
Regards,
Andrej Kolar
glider pilots use
http://www.naviter.com/
On 19 feb., 02:07, "Paul Remde" wrote:
Hi Brian,
Best Regards,
Paul Remde
Paul Remde wrote:
Hi,
 Exit with Ok.
developers.
Paul Remde
Brian W
iPAQ 310 Backlight Dimming Issue Paul Remde Soaring 4 July 17th 09 07:42 PM
Lightnings at War - Backlight.jpg (1/1) Mitchell Holman Aviation Photos 0 January 8th 07 10:31 PM
Still more Airbus woes (3) john smith Piloting 0 June 14th 06 03:37 PM
Still more Airbus woes (2) john smith Piloting 0 June 14th 06 03:35 PM
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
