FS: Vans RV-8
Old March 8th 10, 12:39 PM posted to rec.aviation.homebuilt
Karl Townsend
Default FS: Vans RV-8
Sadly, my father is putting up for sale the project of his life. Its an RV-8
homebuilt airplane. About fifteen years ago, I visited my dad and seen a
pile of AL sheeting and extruded AL support stock for ribs etc. I spent two
days with him fabricating one side of the vertical fin on the tail. I
thought, "there ain't no way". Well, only 6000 logged hours of work later,
it flew. He went on to outfit it with every conceivable electronic
navigation device for full IFR rating.
Here's a couples links. Kinda shows what's involved.
http://www.rv8.ch/
http://www.vansaircraft.com/public/rv-8int.htm
If you're in the market for a meticulously home built aircraft, this is one
hell-of-a deal. Here's the specs:
710- CT ASKING
PRICE---$90,000
SPECIAL AIRWOTTHINESS CERTIFICATE ------------ 09/ 13/ 00
LYCOMING ENGINE- 0-360 A1A 180 HP. ENGINE HAS 500 HOURS AS OF 2/22/10
414 HRS. INSTALLED UNISON SLICK AIRCRAFT MAGS.
OIL AND FILTER HAS BEEN CHANGED EACH 25 HRS. WITH PHILLIPS 20 W-50 OIL AND
12 OZ. AV BLEND
PLANE HAS NEAR NEW MICHELIN TIRES
I CRUISE AT 150 KNTS
HOSES
NEW FLEXIBLE IN 2009
OIL, GASOLINE, INSTRUMENT LINES
OIL COOLER, FUEL PUMP, AND CARBURATOR
RADIOS
GMA 340 AUDIO PANEL
GNS 430 GPS
GTX 327 TRANSPONDER
MX 20 MFD
GI 106 NAV. INDICATOR
ALTITUDE HOLD AUTO PILOT
CARUS 3000 V. STERILIZER
STEC C 1261-17-14 PITCH COMPUTER
STEC 0107-5 PS PITCH SERVO
STEC 0111 TRANSDUCER
GARMIN 3-4-56 GPS ANTENNA
CI-122 COMM. ANTENNA
IMC INSTRUMENTS
3 1/8" ATTITUDE INDICATOR / ELECTRIC
3 1/8" GYRO COMPASS/ ELECTRIC
3 1/8" TURN AND BANK INDICATOR / ELECTRIC
2 ¼" VERTICAL SPEED INDICATOR
SENSENICH AIRCRAFT PROPELLER
PROPELLER MODEL- 72M859-1-83
PROPELLER SERIAL NUMBER - 32942
Pics can be emailed if you're interested.
Karl
Old March 9th 10, 09:20 AM posted to rec.aviation.homebuilt
On Mar 8, 12:39*pm, "Karl Townsend"
thought, "there ain't no way". *Well, only 6000 logged hours of work later,
Here's a couples links. Kinda shows what's involved.http://www.rv8.ch/http://www.vansair...ic/rv-8int.htm
If you're in the market for a meticulously home built *aircraft, this is one
* * * * * * * * * * * * * * * * * * * * * * * * 710- CT * * * * *ASKING
PRICE---$90,000
12 OZ. AV BLEND
HOSES
* * * * * NEW FLEXIBLE IN 2009
* * * * * OIL, GASOLINE, INSTRUMENT LINES
* * * * * OIL COOLER, FUEL PUMP, AND CARBURATOR
RADIOS
* * * * * GMA 340 AUDIO PANEL
* * * * * GNS 430 GPS
GTX 327 TRANSPONDER
MX 20 MFD
* * * * * STEC C 1261-17-14 PITCH COMPUTER
* * * * * STEC 0107-5 PS PITCH SERVO
* * * * * STEC 0111 TRANSDUCER
IMC INSTRUMENTS
* * * * * 3 1/8" ATTITUDE INDICATOR / ELECTRIC
* * * * * 3 1/8" GYRO COMPASS/ ELECTRIC
* * * * * 3 1/8" TURN AND BANK INDICATOR / ELECTRIC
* * * * * 2 " VERTICAL SPEED INDICATOR
* * * * * PROPELLER MODEL- 72M859-1-83
* * * * * PROPELLER SERIAL NUMBER - 32942
Karl
Karl
You can advertise the airplane for free - including a photo - on the
free online aviation magazine www.av8magazine.com
All you need to do is to go to the website, register for free and log-
on to receive the latest issue of the mag. Take a look at the ads
towards the back of each issue - they are split between ads from the
US and those from Europe. As you are now a registered user you can
send an email to the mag with details of the airplane, and a photo -
they will included for free in the next issue.
There's much more to the mag than free ads - including a monthly
feature 'Reach for the Sky' which spotlights homebuilts and
restorations - so check it out.
Old March 9th 10, 11:42 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Karl,
Don't forget to put an add on Barnstormers.
http://www.barnstormers.com/
VANS RV-4 Glenn[_2_] Aviation Photos 0 October 4th 07 08:57 AM
Vans RV-4 Glenn[_2_] Aviation Photos 25 July 18th 07 07:50 AM
Vans RV-10 [email protected] Home Built 3 September 25th 06 06:23 AM
Vans RV-11 Scott Correa Soaring 27 January 5th 04 07:56 AM
Vans RV-G glider Mark James Boyd Soaring 16 November 6th 03 10:03 PM
