Do you have electricity at your trailer?
There is a device called Dampp-Chaser that is used inside pianos to keep them from soaking up humidity. It is a long rod that is heated electrically and will elevate temperature enough to keep a piano dry (but not too dry). Two or three of these strategically placed might do the job. I believe they are available in more than one length. |
On Mar 29, 8:52*pm, None wrote:
Do you have electricity at your trailer? There is a device called Dampp-Chaser that is used inside pianos to keep them from soaking up humidity. *It is a long rod that is heated electrically and will elevate temperature enough *to keep a piano dry (but not *too dry). *Two or three of these strategically placed might do the job. *I believe they are available in more than one length. When my repair shop was open we would open all trailers regularly and the metal trailers were always wet inside. The fiberglass tops weren't, neither were the wood trailers. I believe the moisture came from condensation and would build up inside to the point the ceiling would be dripping water droplets over time. Recommend opening your trailer as often as possible and installing a solar fan with a small vent on the floor at the opposite end of the trailer so the fan can change-out all the moist air during the day when the solar fan is operating and the air isn't so damp. Left long enough and moisture will build up inside the cockpit, ever notice rusty bolts in your cockpit? I even saw one bird with moisture inside the instruments, but the trailer hadn't been opened in years! Cheers, JJ |
On Mar 29, 10:52*pm, None wrote:
Do you have electricity at your trailer? There is a device called Dampp-Chaser that is used inside pianos to keep them from soaking up humidity. *It is a long rod that is heated electrically and will elevate temperature enough *to keep a piano dry (but not *too dry). *Two or three of these strategically placed might do the job. *I believe they are available in more than one length. The cheapo solution is a 60 watt lightbulb. Better, you can buy for $40 a bilge heater at a boat store. This is a 40 watt heater designed to go in the bottom of a boat -- where they have the same problem -- to warm it up just enough to stop condensation. I use this in the winter. Our gliders at least go in a hangar in the winter, but guess what, a hangar can be worse than outside. A huge slab of cold concrete is a water magnet on those spring mornings, and by being inside the solar vents don't work. If you have power, of course, a dehumidifier is even better. The problem I still haven't solved is spring/summer, aluminum top, no power available to trailer. Filling the trailer with water absorbers as you find in the hardware store helps -- at least the water absorbers fill up giving some psychological relief. Here's a challenge for all our talented backyard engineers! How can we stop this daily condensation cycle for trailers parked outside away from power? John Cochrane |
![]() Here's a challenge for all our talented backyard engineers! How can we stop this daily condensation cycle for trailers parked outside away from power? How about packing trailer with those lovely little silica "Do Not Eat Dessicant Package" thingies that come in electronics packages? They would absorb the moisture. You would only need to take the packing out every once in a while (depending on the humidity) and bake them to remove the moisture and re-use. (and yes, tongue is planted firmly in cheek). |
On Mar 30, 7:20*am, John Cochrane
wrote: On Mar 29, 10:52*pm, None wrote: Do you have electricity at your trailer? There is a device called Dampp-Chaser that is used inside pianos to keep them from soaking up humidity. *It is a long rod that is heated electrically and will elevate temperature enough *to keep a piano dry (but not *too dry). *Two or three of these strategically placed might do the job. *I believe they are available in more than one length. The cheapo solution is a 60 watt lightbulb. Better, you can buy *for $40 a bilge heater at a boat store. This is a 40 watt heater designed to go in the bottom of a boat -- where they have the same problem -- to warm it up just enough to stop condensation. I use this in the winter. Our gliders at least go in a hangar in the winter, but guess what, a hangar can be worse than outside. A huge slab of cold concrete is a water magnet on those spring mornings, and by being inside the solar vents don't work. If you have power, of course, a dehumidifier is even better. The problem I still haven't solved is spring/summer, aluminum top, no power available to trailer. Filling the trailer with water absorbers as you find in the hardware store helps -- at least the water absorbers fill up giving some psychological relief. Here's a challenge for all our talented backyard engineers! How can we stop this daily condensation cycle for trailers parked outside away from power? John Cochrane Suggestion 1: Move west to a dry climate and get better soaring in the bargain. |
![]() Suggestion 1: Move west to a dry climate and get better soaring in the bargain.- Hide quoted text - that doesnt sound very challenging ![]() |
stop this daily condensation cycle for trailers parked outside away from power? John Cochrane Oreos tend to absorb moisture. And they make a pretty neat snack after a strenuous session of glider rigging! Signed, The Cookie Monster |
Oreos tend to absorb moisture. *And they make a pretty neat snack
after a strenuous session of glider rigging! Signed, The Cookie Monster Says the guy with a Glasflugel 604 ! |
In search of drier trailers | Martin Gregorie[_5_] | Soaring | 2 | March 30th 10 12:47 AM |
open trailers | [email protected] | Soaring | 1 | December 5th 06 04:41 PM |
F/S: Pik-20 and PW-5 trailers | DB | Soaring | 0 | August 9th 05 02:44 PM |
Trailers | Don Johnstone | Soaring | 2 | July 13th 05 09:30 PM |
Pic trailers | culverflyer | Soaring | 1 | May 5th 04 01:37 AM |
