O200 engine pressure
Old April 6th 10, 08:36 AM posted to rec.aviation.homebuilt
Philippe[_4_]
Default O200 engine pressure
Hello,
is anyone may confirm some type of crankcase internal crack cause oil
pressure drop?
thanks
Pub: http://www.cd1d.com/
Philippe Vessaire Ò¿Ó¬
Old April 6th 10, 12:00 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 06 Apr 2010 09:36:32 +0200, Philippe
Hello,
pressure drop?
thanks
drain the oil and take the football off the bottom of the engine (oil
sump) and have a look up inside using a thousand candle power
spotlight. you can see it all before you.
you just need to have a new gasket available for the sump to engine
joint.
as to the question. havent experienced it with my O-200 but with the
spotlight and an inspection mirror you should be able to confirm the
suspicion or put your mind at ease.
Stealth Pilot
Old April 6th 10, 07:06 PM posted to rec.aviation.homebuilt
Philippe[_4_]
le mardi 6 avril 2010 13:00, Stealth Pilot s'est penché sur son
joint.
thanks for the answer... I will do.
Old April 15th 10, 04:46 AM posted to rec.aviation.homebuilt
On Apr 6, 5:00*am, Stealth Pilot
On Tue, 06 Apr 2010 09:36:32 +0200, Philippe *
Hello,
*is anyone may confirm some type of crankcase internal crack cause oil
pressure drop?
thanks
joint.
Stealth Pilot
Low oil pressure in a small Continental is usually due either
to worn bearings, a worn oil pump, a loose oil pump cover, or a
sticking oil pressure relief valve and maybe a broken relief valve
spring. I'd take the accessory cover off first (while that oil tank is
off) and check out the pump. The relief valve is under a brass acorn-
headed plug on the RH side of the accessory case.
Dan
O200 titan cylinders Philippe Vessaire[_3_] Home Built 7 November 4th 08 06:10 PM
O200 cylinder Philippe Vessaire[_3_] Home Built 3 October 19th 08 11:21 AM
O200 engine Philippe Vessaire Home Built 7 August 17th 07 08:53 PM
O200 nose Philippe Home Built 0 July 22nd 05 08:09 PM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
