SR-71
Old April 18th 10, 09:50 AM posted to alt.binaries.pictures.aviation
Glenn[_2_]
Default SR-71
Old April 18th 10, 02:21 PM posted to alt.binaries.pictures.aviation
Dr.Smith
Default SR-71
"Glenn" wrote in message
Great shot! What kind of camera and lens were you using?
Old April 18th 10, 10:01 PM posted to alt.binaries.pictures.aviation
Morgans[_2_]
Default SR-71
In this picture, a couple feet back on the chine on both sides, there is a
blunted, pushed in area on the chines. Almost looks like the nose ran into
a round hole in a wall, and dented the chines. Of course, I doubt that
happened.
What is the story with that? I had never noticed that on other models of
the 71. Is that damage, or a feature, and if it is a feature, what is it
designed to do - if you or someone knows?
Old April 18th 10, 10:17 PM posted to alt.binaries.pictures.aviation
Canuck[_9_]
Default SR-71
"Morgans" wrote in message
into a round hole in a wall, and dented the chines. Of course, I doubt
that happened.
The original aircraft from which the SR-71 sprang was the Lockheed A-11. It
then morphed into the YF-12. Finally, it became the SR-71. The A-11 and the
YF-12A sported a different nose/chine configuration than what you finally
got to see on the SR_71.
Nick
Old April 19th 10, 04:41 AM posted to alt.binaries.pictures.aviation
Maple1
Default SR-71
Not that one it is an sr71 I believe that is a later modification
is a blunted, pushed in area on the chines. Almost looks like the
nose ran into a round hole in a wall, and dented the chines. Of
course, I doubt that happened.
of the 71. Is that damage, or a feature, and if it is a feature, what
is it designed to do - if you or someone knows?
It then morphed into the YF-12. Finally, it became the SR-71. The A-11
and the YF-12A sported a different nose/chine configuration than what
you finally got to see on the SR_71.
Nick
Old April 19th 10, 06:14 AM posted to alt.binaries.pictures.aviation
Canuck[_9_]
Default SR-71
"Maple1" wrote in message
and the YF-12A sported a different nose/chine configuration than what you
Nick
Hmmmm....curious/strange. I went and had a look and you are right. My foggy
memory failed me. The A-11/YF-12A nosecones were different but not like what
is present in that image. It almost seems like an intermediate morph between
the A-11/YF-12A and the SR-71.
The other possibility is that someone bent it.
Nick
Old April 19th 10, 01:48 PM posted to alt.binaries.pictures.aviation
John Szalay
Default SR-71
"Morgans" wrote in
Those "dents" are the modification for the ECM antennas.
(Electronic counter measures)
Old April 19th 10, 02:00 PM posted to alt.binaries.pictures.aviation
John Szalay
Default SR-71
"Canuck" wrote in
foggy memory failed me. The A-11/YF-12A nosecones were different but
not like what is present in that image. It almost seems like an
intermediate morph between the A-11/YF-12A and the SR-71.
Nick
Attachment decoded: YF-12A.jpg
------=_NextPart_000_0009_01CADF55.58129EF0--
This photo is the YF-12A and the chine mod is for the ASG-18 fire
control radar. to insure directional stability for the chine being cut
three small fins were added to the rear of the underside of the YF-12A
Old April 19th 10, 02:39 PM posted to alt.binaries.pictures.aviation
Peter Twydell[_2_]
Default SR-71
In message , John Szalay
writes
"Morgans" wrote in
I thought they were where the ground crew were supposed to push if the
brakes failed...
Peter
Ying tong iddle-i po!
Old April 19th 10, 03:21 PM posted to alt.binaries.pictures.aviation
Dr.Smith
Default SR-71
into
happened.
I just dug this one out of an old file. The SR-71 at Barksdale AFB in
Louisiana has the same indentions.
