Greetings, group!
Our local club has a pair of L-13s. In one of them, we recently discovered a badly-corroded elevator cable. The corrosion area was located was approx. 15" aft of the bellcrank attachment, under the port-side, aft cockpit flooring -- *very* difficult to get to. It would appear from the extent of the corrosion that this particular spot was not noticed during annual- and/or 100-hour inspections. First, a heads-up to other Blanik L-13 operators: you may want to take a really careful look at the state of your elevator cables, especially in that 15"-aft-of-bellcrank spot on the port side cable. The small, semi-enclosed space in this area of the cable run is both A/ impossible to see without flashlights and mirrors (or an endoscope), and B/ exposed to moisture from e.g. wheel-thrown debris and cockpit condensation. Second: we've been told that new cables will cost $490.00 each (!) from Videck, and take upwards of 3 weeks to get here. I know aviation parts are rarely inexpensive, but $500+ (with shipping) for a 20-foot, 3/16" galvanized steel cable with eyes and swages seems exccessive; similarly-built Piper and Cessna control cables, while admittedly somewhat shorter, tend to run about $100. Does anyone know of a reason why a less costly option, like ordering some custom cables from Aircraft Spruce, wouldn't be legal/safe/ practical? Are there any other suggestions that might help our little non-profit club avoid or mitigate a potential bill of $2,000.00 for 4 cables, and a month-long grounding of our Blaniks while we wait for them to arrive? Thanks in advance, Brad |
On Apr 21, 10:44*am, Brad wrote:
...Does anyone know of a reason why a less costly option, like ordering some custom cables from Aircraft Spruce, wouldn't be legal/safe/ practical? *Are there any other suggestions that might help our little non-profit club avoid or mitigate a potential bill of $2,000.00 for 4 cables, and a month-long grounding of our Blaniks while we wait for them to arrive? Brad, I would suggest that you contact McFarlane Aviation, from whom I have sourced custom cables in the past. They also sent me a free T-shirt with the last order, so I must have full-on BTDT. As for the bureaucracy aspect, as usual that issue depends on who you talk to, how, and when. My suggestion would be to get an A&P you can work with who would be willing to install the cables as owner-produced parts as specifically allowed under 14CFR§21.303(b)2: http://ecfr.gpoaccess.gov/cgi/t/text...1.11.2&idno=14 As usual, my favorite article on owner-produced parts by Don Dodge describes the process and offers a cautionary tale: http://150cessna.tripod.com/parts.html Your "owner's" contribution to the manufacture could be as simple as creating the diagrams and specifications that McFarlane (or whoever). Probably the greatest hurdle you will encounter is that the Blanik will have metric cables and fasteners, and McFarlane or whoever will probably only have inch-sized MS-series cable, swages, and fittings. So you either have to bite the bullet and source the cable from a metric-capable cable firm, or you have to develop some way of adapting inch-sized cable fittings to horns with metric holes. If the horns have generous edge clearance, it could be a simple as drilling 6mm (0.236") holes up by .014" to 1/4". Or it could be much more complicated. Regardless, that is the sort of thing that you absolutely must first square away with the A&P or IA who signs off the installation and subsequent inspections. In the end, you may find it more effective and expedient to just pay the $500 per cable. Thanks, Bob K. |
![]() In the end, you may find it more effective and expedient to just pay the $500 per cable. I agree with above - Nothing is as easy as it looks especially if you have not BTDT. However, if one were to design your own cable, how do you go about getting the specs and properites of the original cables and the end fittings turnbuckles, ect? Sure, one could generously oversize the cable so it "looks" right, and get someone to buy it off, but will it fit the pulleys and pass thoughs in the aircraft? I have this week a need for another part fron Vitek, any way one could request expedited shipping? Also, there are some scrapped ships I know of - check with some aircraft salvage yards aerodyne |
On Apr 21, 12:13*pm, wrote:
However, if one were to design your own cable, how do you go about getting the specs and properites of the original cables and the end fittings turnbuckles, ect? * That's actually one of the easier aspects. The design of cable- actuated control systems is very well understood, and there is plenty of engineering guidance in standard design and maintenance texts. I'd probably start with AC43.13; in change 1B of that advisory circular cables are covered in some depth in Chapter 7. The maximum strength of the various sizes and configurations are shown in table 7-4, and paragraph 7-148(a) advises that "Swage-type terminals, manufactured in accordance with AN, are suitable for use in civil aircraft up to, and including, maximum cable loads." As for reverse-engineering the properties of the LET original cable, I'd probably begin with the reasonable assumption that the strength of the cable is typical of aircraft-grade control cable of similar configuration and cross-sectional area. That's based on the equally reasonable assumption that they were't making Blaniks out of Unobtanium in Soviet-era Czechoslovakia. But, just to make sure, I'd probably also fabricate a test article using a piece of the original cable with at least one original terminal and pulling it to tensile failure in my tensile test machine. If AC43.13 change 1B table 7-4 is to be believed, I can pull to failure any cable assembly up to and including 9/32" (0.281" or 7.14mm), and from a design perspective I'd expect the elevator cable to be about half that size. Thanks again, Bob K. |
I don't agree...
The problem is you are leading folks down a slippery slope. There is more to meeting the design intent of a certificated part than conservative assumptions and good intentions. One thing I know from parsing JAR-22 and older European design criteria is that they do things differently, mainly safe life vs fail safe. They still have this approach today, one modern glider requires ALL cables to be replaced every 10 years. Have you ever compared the countersink depth and angle from the "5" rivet on the Blanik with a NAS1097 or NASM20426? I did the layout, and they are not the same geometry. I have never seen the proper factory rivets used in a Blanik repair, and the folks doing the work are completely unaware of the nuances of bearing properties of mismatched flush rivet in csk or dimpled structure. They would not know the principle of bearing bypass if it hit them upside the head. If one does not have skills or experience, "designing" something based on a single data point from a used, damaged old part does not meet the intent of the FAR's or certification criteria, even if you do have a tensile tester and know how to use it AND reduce the data to "B" basis, ect. You need the original design data and specs, and Blanik has extensive overhaul, repair, and maintenance manuals. BTW, AC-43-13 cannot be used if you can't ensure that the data therein is not contrary to the Mfg data. Lets encourage folks to support the Mfg and buy the right parts if available. lf we all did that, perhaps they will stay in business and the prices will come down. aerodyne |
On Apr 21, 5:21*pm, wrote:
...Have you ever compared the countersink depth and angle from the "5" rivet on the Blanik with a NAS1097 or NASM20426? *I did the layout, and they are not the same geometry... "Aerodyne," that's the other thread. This one is about the elevator cables. Thanks, Bob K. |
Brad wrote:
Greetings, group! Our local club has a pair of L-13s. In one of them, we recently discovered a badly-corroded elevator cable. The corrosion area was located was approx. 15" aft of the bellcrank attachment, under the port-side, aft cockpit flooring -- *very* difficult to get to. It would appear from the extent of the corrosion that this particular spot was not noticed during annual- and/or 100-hour inspections. First, a heads-up to other Blanik L-13 operators: you may want to take a really careful look at the state of your elevator cables, especially in that 15"-aft-of-bellcrank spot on the port side cable. The small, semi-enclosed space in this area of the cable run is both A/ impossible to see without flashlights and mirrors (or an endoscope), and B/ exposed to moisture from e.g. wheel-thrown debris and cockpit condensation. Second: we've been told that new cables will cost $490.00 each (!) from Videck, and take upwards of 3 weeks to get here. I know aviation parts are rarely inexpensive, but $500+ (with shipping) for a 20-foot, 3/16" galvanized steel cable with eyes and swages seems exccessive; similarly-built Piper and Cessna control cables, while admittedly somewhat shorter, tend to run about $100. Does anyone know of a reason why a less costly option, like ordering some custom cables from Aircraft Spruce, wouldn't be legal/safe/ practical? Are there any other suggestions that might help our little non-profit club avoid or mitigate a potential bill of $2,000.00 for 4 cables, and a month-long grounding of our Blaniks while we wait for them to arrive? Thanks in advance, Brad I have no special insights other than a well-developed wallet nerve about aircraft ownership costs. There are general design rules about control surfaces: one that comes to mind is the design load specified for rudder pedals (for example): shall withstand 100 lb force on each pedal, with a 150% design factor (if my memory serves). If a person wanted to select the appropriate aircraft cable and the appropriate terminals and found a competent Yacht chandler and gave EXACT measurements or preferably provided the old cables with a stretch allowance, AND above all, carried out a proof test on the manufactured cable AND kept it off the books, then costs would be reduced. Thankfully, I can simply ask my A&P to fit the replacement rudder cables he is ordering for me, when they arrive. As you note - for popular types the costs are not out of line for approved components. Introducing a worry factor of this kind, when the pilot is going to seek out bumpy conditions would not be a happy prospect, to my way of thinking. Brian W |
On Apr 21, 11:44*am, Brad wrote:
Greetings, group! Our local club has a pair of L-13s. *In one of them, we recently discovered a badly-corroded elevator cable. *The corrosion area was located was approx. 15" aft of the bellcrank attachment, under the port-side, aft cockpit flooring -- *very* difficult to get to. *It would appear from the extent of the corrosion that this particular spot was not noticed during annual- and/or 100-hour inspections. First, a heads-up to other Blanik L-13 operators: you may want to take a really careful look at the state of your elevator cables, especially in that 15"-aft-of-bellcrank spot on the port side cable. *The small, semi-enclosed space in this area of the cable run is both A/ impossible to see without flashlights and mirrors (or an endoscope), and B/ exposed to moisture from e.g. wheel-thrown debris and cockpit condensation. Second: we've been told that new cables will cost $490.00 each (!) from Videck, and take upwards of 3 weeks to get here. *I know aviation parts are rarely inexpensive, but $500+ (with shipping) for a 20-foot, 3/16" galvanized steel cable with eyes and swages seems exccessive; similarly-built Piper and Cessna control cables, while admittedly somewhat shorter, tend to run about $100. Does anyone know of a reason why a less costly option, like ordering some custom cables from Aircraft Spruce, wouldn't be legal/safe/ practical? *Are there any other suggestions that might help our little non-profit club avoid or mitigate a potential bill of $2,000.00 for 4 cables, and a month-long grounding of our Blaniks while we wait for them to arrive? Thanks in advance, Brad Sorry Brad, all I can offer is tea and sympathy. I went through this a year ago with one of our club Blaniks, but the cost was higher because we had to do both rudder and elevator cables. The problem with Blaniks is that time and metal are not our friends. None of the L-13's is less than thirty years old. I've come to believe that the reason that they are so cheap to buy is that the market has factored in the cost of maintaining them. I haven't done the calculations, but its my general impression that Blanik parts prices have about quadrupled since 2005. And as one aircraft mechanic pointed out to me, they were designed in the 50's when labor was cheap, so no thought was given to minimizing repair labor effort. At least your parts are in stock. We had one damaged in a landing accident and the parts required had to be made up by the factory. The order was placed in mid September and we received them in mid February. I suspect that a lot of this has to do with the fact that when the Czech republic came out of a communist system, parts prices were artificially low, and now that they fully realize the price required to sustain a profitable manufacturing and inventory operation, they've swung all the way the other way to excessive prices. When you also look at what's happening with DG, you start to wonder if the cost of sustaining legacy aircraft isn't a serious long term issue that constitutes yet another threat to the viability of our sport. Sandy Stevenson |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
USA: FAA AD for Blanik L-23 elevator hinges | Burt Compton - Marfa | Soaring | 6 | April 7th 10 02:10 PM |
Blanik L13 Windscreen Replacement | Mike125 | Soaring | 13 | February 25th 09 07:32 PM |
Prop Cable - Replacement Needed | zatatime | Owning | 0 | May 7th 04 04:37 PM |
Nimbus 3 25.5 tip spoiler cable replacement | tango4 | Soaring | 0 | May 3rd 04 09:05 PM |
