DG1000 Tail Battery
Old April 28th 10, 07:57 AM posted to rec.aviation.soaring
pp2076
Default DG1000 Tail Battery
Does anyone have details of the fin (tail) battery used in the DG1000
ie make and model?
I presume that this is an off-the-shelf item rather than something
custom made for DG.
Any details appreciated, especially contact details of a
supplier( even better if that supplier is in Australia )
Thanks
Old April 28th 10, 08:57 AM posted to rec.aviation.soaring
weersch[_2_]
We had a damaged/worn-out tail battery in our club DG1000S.
We ordered a replacement from DG at a very high cost.
After that I disassembled the original.
It consisted simply of 4 Panasonic LC-R067 R2P (6Volt, 7.2 Ah)
batteries.
150mm x 94 mm x 34mm each.
Switched 2 serial x 2 parallel for a total of 12V, 14.4 Ah.
All of it is simply double-sided taped to eachother and to a flat
aluminum strip ending in the bracket with fuse, connector and grip on
top.
Then heat shrink wrapped.
Would have been very easy to replace yourself with some very basic
handyman experience at a cost of about US$75.
Hans Van Weersch
restraining oxy bottle in a DG1000 Pawnee Pilot Soaring 3 November 19th 09 08:49 AM
DG1000/2 Frank Whiteley Soaring 10 December 12th 08 05:14 PM
DG-1000 Tail Battery Connector. Where to get one? Jeremy Zawodny Soaring 7 January 4th 07 02:50 PM
Video or the DG1000 spin in Mal Soaring 5 September 12th 04 07:41 AM
Duo Discus vs. DG1000 in a stall? Gldcomp Soaring 2 September 2nd 04 09:24 PM
