I know there has been several threads on making new glider placards to
replace old, hard to read ones. However, I think I have just found something new that might be the best idea yet. See: http://www.horizonsisg.com/alumajet/...-aluminum.html These days, "archival quality, UV resistant ink" is available from most inkjet manufacturers which, with a good clear coat, should make very durable and highly attractive labels and placards. AlumaJet sheets aren't cheap at $60 for a 10 sheet pack but the quality might be worth it for some. Bill D |
On May 9, 6:42*am, bildan wrote:
I know there has been several threads on making new glider placards to replace old, hard to read ones. *However, I think I have just found something new that might be the best idea yet. See:http://www.horizonsisg.com/alumajet/...ntable-aluminu.... These days, "archival quality, UV resistant ink" is available from most inkjet manufacturers which, with a good clear coat, should make very durable and highly attractive labels and placards. AlumaJet sheets aren't cheap at $60 for a 10 sheet pack but the quality might be worth it for some. Bill D I started using the AlumaJet for the name plates on my Craggy Aero Ultimate Flight Computer. It requires a J path printer for the .005" tickness or straight path printer for the thicker sheets. Most standard printers won't work as they bend the paper 180 degrees. Nice stuff and would work well for cockpit templates. Richard www.craggyaero.com |
These days, "archival quality, UV resistant ink" is available from most inkjet manufacturers which, with a good clear coat, should make very durable and highly attractive labels and placards. AlumaJet sheets aren't cheap at $60 for a 10 sheet pack but the quality might be worth it for some. and for the less industrious folk: http://yourlookingforwhat.net/main/ac_products.htm -Paul |
sisu1a wrote:
See:http://www.horizonsisg.com/alumajet/...ntable-aluminu... These days, "archival quality, UV resistant ink" is available from most inkjet manufacturers which, with a good clear coat, should make very durable and highly attractive labels and placards. AlumaJet sheets aren't cheap at $60 for a 10 sheet pack but the quality might be worth it for some. and for the less industrious folk: http://yourlookingforwhat.net/main/ac_products.htm -Paul My thought too. I bought a production metal placard to prohibit intentional spins in order to comply with an FAA directive from last year. It was under $10 This was a quantity product,no doubt - it affects all C-150s but still.... Brian W |
Making Placards | Charlie | Home Built | 13 | December 7th 06 03:37 AM |
Replacing Cockpit placards | toad | Soaring | 9 | March 28th 06 03:04 PM |
Cockpit Placards | Brian Iten | Soaring | 9 | January 14th 05 04:11 AM |
what placards are required? | Dave Butler | Owning | 3 | June 3rd 04 09:03 PM |
Fuel Transfer Placards | Ben Smith | Owning | 22 | October 16th 03 02:32 PM |
