Directions And Compasses ?
Old May 30th 10, 10:28 PM posted to rec.aviation.piloting
Bob
Default Directions And Compasses ?
Hello,
Am not a pilot, but was wondering about this.
In commercial aviation, and I guess for private flying also, when
directions are given, are they assumed to be True or Magnetic ?
What do pilots use these days for direction ?
I assume a gyro compass of some sort but am not sure. Is this correct ?
If so, is this Magnetic or True ?
I can't believe they spend the effort converting from one to another.
Do they ?
Are chart roses they use shown as True or Mag. ?
What's in the cockpit ?
Do they still have a Mag. compass there ?
Any thoughts would be most appreciated.
Bob
Old May 30th 10, 10:47 PM posted to rec.aviation.piloting
Bob wrote:
Hello,
Almost everything is magnetic.
Gyro based direction indicators are set from the magentic compass and are
called heading indicators.
The true gyrocompasses used in ships are not used in airplanes.
Do they ?
Yes.
Depends on what you mean by "chart roses".
Aviation charts have rings around VOR stations that are magnetic.
They also have true NSEW grid lines and lines showing the local magnetic
variation.
It is one of the few instruments required by regulation for all airplanes.
OK, there are more than just floating needle magnetic compasses these days.
http://en.wikipedia.org/wiki/Fluxgate_compass
Bob
Jim Pennino
Remove .spam.sux to reply.
Old May 30th 10, 11:06 PM posted to rec.aviation.piloting
a[_3_]
On May 30, 5:28*pm, Bob wrote:
Hello,
I assume a gyro compass of some sort but am not sure. *Is this correct ?
Do they ?
Bob
Winds aloft are given with true, but we use magnetic for aviation/
navigation. We have magnetic compasses in the cockpit, and we set the
DG to correspond to it. Part of most preflight checklists, especially
instrument flight rules flights, is (or should be) to verify that the
magnetic compass is working. Nav compass roses are magnetic on the
charts we use.
Old May 31st 10, 03:23 AM posted to rec.aviation.piloting
Morgans[_2_]
charts we use.
It should be noted that minimum instruments for single engine aircraft
include magnetic compass. I don't know how far up the aircraft size this
holds true.
Old May 31st 10, 03:29 AM posted to rec.aviation.piloting
Hey Bob,
My airplane I used to own would be typical of your GA plane.
See http://www.youtube.com/watch?v=ki79yX4bhJ4 for what I had for
equipment that may answer your question.
Video includes startup, runup and shutdown procedures for a Beechcraft
Sundowner. The video was done before I started recording ATC and
intercom communications but you still can hear what I am saying as I
go through the checks.
Vertical Card Compasses vs GPS Compass Display [email protected] Soaring 16 September 25th 07 06:44 AM
[ATTN] Jim Weir or anyone knowing about old gyro compasses B.B. Home Built 1 November 22nd 04 05:49 PM
Vertical card compasses Dan Luke Owning 13 March 1st 04 11:23 PM
Marfa Task areas & directions chris Soaring 1 December 3rd 03 01:12 AM
