SN10 Questions
Old June 7th 10, 12:30 AM posted to rec.aviation.soaring
Barny
Default SN10 Questions
After about 50 flights with a SN10 and having RTFM many times plus
testing with the PC version, I have a couple questions:
1) When I turn to the Alternates page, instead of showing the #1 & #2
closest airports, it shows arbitrary airports, perhaps ones that I've
previously selected on other flights. These may be #32 and #56
closest, not very helpful when you need a close airfield. This is
remedied by rotating the value to #1, but this seems silly to have one
more pilot task during a high stress situation. Am I missing
something?
2) I just flew my first contest, which had a 5 mile start cylinder.
The only thermal around happened to be on the cylinder edge and it was
a massive 1.5 knots, so I got to spend a nice long time watching and
listening to the SN10 tell me "you're inside the start cylinder, press
help to clear this message", then 1/2 a circle later "you're outside
the start cylinder, press enter to make a start, press help to clear
this message". To access the Custom page and see my climb rate I had
to clear these messages every 1/2 circle. I presume this is one reason
guns are not allowed in the cockpit. Do I set Task Rules, Start: =
None, then change it back to cylinder after I climb up?
Thanks, Bruce
Old June 7th 10, 01:21 AM posted to rec.aviation.soaring
Dave Nadler
something?
Yes. Set the alternates you are considering, and they stay put
even though the ordinals change. Spin the value knob fast and
the ordinal goes immediately to #1.
this message". *To access the Custom page and see my climb rate I had
Just leave the warning on the screen. You certainly don't need
to be looking at the panel every 1/2 circle when in the start area
surrounded by other gliders...
Thanks, Bruce
Hope that helps,
Best Regards, Dave
SN10 USB connection kirk.stant Soaring 13 April 14th 10 02:25 PM
SN10 B for sale Dick[_3_] Soaring 1 November 29th 09 07:31 PM
SN10 Remote Repair Mike the Strike Soaring 5 February 19th 08 03:24 PM
SN10 Simple Glide Calculator Page questions Frank Soaring 2 February 8th 06 01:16 AM
SN10 Remote BMacLean Soaring 0 August 24th 03 11:32 PM
