Welding on your head
Old June 8th 10, 12:48 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welding on your head
I've gotten pretty good with my OA welds; I spent the last three
months practicing a splice by inner sleeve and am pleased that after
much practice I can melt the three components together and get good
penetration. On the bench.
However, when I tried welding on the fuselage, it's an entirely
diffferent situation. Just like they don't tell you that 95% of the
effort is jigging things into position, they don't tell you the other
95% is positioning the work so that you can work comfortably.
On the bench, everything is timed and measured and meticulous; if I'm
welding from the side, things get tense.
Am I correct that this is going to turn into weld-a-little,t urn the
work .weld-a-little, turn the work?
Can someone share any hints on how to support your forearm? - Mike
Old June 8th 10, 01:02 AM posted to rec.aviation.homebuilt
Brian Whatcott
Now THERE'S an on-topic post, if I ever saw one!
Brian W
Old June 8th 10, 01:56 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yep'er!
How about the advice to put the fuselage on a rotating gig?
Sometimes you have to build a gig to build a gig!
Lacking that, start at the bottom of the weld, and work your way up, and
stop to cool the work every little bit. I mean little bit, too. Sometimes
that will help your filler from not running down and pooling at a low spot.
Sometimes it takes cooling an area with wet rags.
As far as supporting your forearms, don't-just get them in better fudging
shape ! ! ! g
Morgans[_2_]
Yep'er!
shape ! ! ! g
Morgans[_2_]
Yep'er!
shape ! ! ! g
Morgans[_2_]
Yep'er!
shape ! ! ! g
Old June 8th 10, 06:34 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Sorry for the triple stutter, all.
Old June 8th 10, 08:38 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Mon, 7 Jun 2010 20:56:15 -0400, "Morgans"
Yep'er!
shape ! ! ! g
forearm exercises.
more beer drinking?
Old June 9th 10, 06:32 AM posted to rec.aviation.homebuilt
Dan[_12_]
Yep'er!
shape ! ! ! g
forearm exercises.
more beer drinking?
12 ounce curls.
Dan, U.S. Air Force, retired
Old June 9th 10, 08:21 AM posted to rec.aviation.homebuilt
Oliver Arend
* *12 ounce curls.
12 oz?
How about:
http://p3.focus.de/img/gen/x/E/HBxEX...en_r_220xA.jpg
Oliver
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 1 March 26th 09 07:20 AM
gas welding aid 2 - welding clamp 2.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:58 AM
gas welding aid 2 - welding clamp 2.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:57 AM
Gas Welding Aid 1 - welding clamp 1.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:50 AM
whoelsale bose head phones,wireless head phones,wireless headphone,3.5mm earphone,earphone Alex[_4_] Aerobatics 0 April 21st 08 03:35 PM
