Mods to glider = experimental?
Old June 16th 10, 05:24 PM posted to rec.aviation.soaring
Bret
Default Mods to glider = experimental?
What kind of mods to a glider force it to be reclassified as
experimental?
Does making your own winglets cross that line?
What is process for getting it reclassified?
Old June 16th 10, 05:32 PM posted to rec.aviation.soaring
lanebush
If it is no longer in the configuration as described in the type
certificate plus any STC 's and/or field approved modifications. So,
if your winglets are not approved via an STC or field approval (337
form) and are not listed in the type certificate then you are not
flying under a valid airwothiness certificate. There is the question
of major/minor modification/repair but I believe winglets would not
pass the test of being excluded from the "major" catagory.
Old June 16th 10, 06:30 PM posted to rec.aviation.soaring
Bret
certificate plus any STC 's and/or field approved modifications. *So,
flying under a valid airwothiness certificate. *There is the question
of major/minor *modification/repair but I believe winglets would not
True there are lots of STCs about winglets.
Old June 16th 10, 09:29 PM posted to rec.aviation.soaring
jb92563
If there is already and STC or 337 for the modification you want to
make on your plane type then you are
on easy street as they have paved the way for your Mod to be accepted
by the FAA.
However reclassing a once certificated Glider as experimental may not
always even be allowed
as one of the other recent discussion topics revealed, in the case of
a DG 505.
HVX MODS on VW engines Veeduber[_2_] Home Built 0 June 18th 09 09:57 PM
Diamonds & HVX MODS [email protected] Home Built 0 January 26th 09 09:30 PM
Licensing new Experimental glider in USA John Bojack[_2_] Soaring 5 January 2nd 09 01:54 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
mods for a Cherokee 140 Tony Woolner Owning 8 January 7th 04 12:20 PM
