Zero to Hero in one flight
Old June 18th 10, 05:39 PM posted to rec.aviation.soaring
Tony[_5_]
Default Zero to Hero in one flight
Back in the good old days the Diamond Goal did not have to be a closed
course. Did anyone ever go from no badges whatsoever and do a +5 hr
declared 500+km straight distance flight along with a 5000 meter
altitude gain to claim Silver, Gold, and all 3 diamonds on the same
flight?
Old June 18th 10, 06:01 PM posted to rec.aviation.soaring
Andy[_1_]
course. *Did anyone ever go from no badges whatsoever and do a +5 hr
flight?
Don't know about that one but several 1-26 pilots have attempted to
get all 3 diamonds in one flight and at least one came very close.
Perhaps it has been done now.
Andy
Old June 18th 10, 07:45 PM posted to rec.aviation.soaring
Greg Arnold[_3_]
flight?
I believe you could still get all the badges on one flight if you do a
500 km declared O&R with diamond elevation gain. If you start off in a
wave window, it might not be hard. In thermals, it would be harder
while remaining under 18,000'. I remember a SOARING article a few years
ago about a pilot who did a three diamond thermal flight, with the low
point being in Death Valley in California.
Old June 18th 10, 08:09 PM posted to rec.aviation.soaring
Tony[_5_]
flight?
500 km declared O&R with diamond elevation gain. *If you start off in a
wave window, it might not be hard. *In thermals, it would be harder
while remaining under 18,000'. *I remember a SOARING article a few years
true, i always forget that you can do the 500 km task closed course if
you wish. so i guess there still is potential to go from zero to hero
in one flight.
Old June 18th 10, 08:16 PM posted to rec.aviation.soaring
Ramy
flight?
That was Sergio! To achieve this he needed to open his spoilers to get
down to something like 1000 ft AGL over the Death Valley in 120
degrees heat...
Ramy
Old June 18th 10, 09:50 PM posted to rec.aviation.soaring
kirk.stant
flight?
degrees heat...
Ramy
A pilot in Arizona also did a three-diamond thermal flight (that also
happened to be an "all badges at one whack" flight) back in 2001,
using the Grand Canyon South Rim lookout as one of his turnpoints.
Low point was under 1000' agl just off tow, near Turf. Cloud base
over the Canyon was up around 23,000' that day....
Cuts down on the paperwork nicely.
Kirk
66
The Un-Sung Hero of Parawan [email protected] Soaring 7 July 17th 07 05:45 PM
a hero passes Ray O'Hara[_2_] Aviation Photos 21 May 7th 07 11:31 AM
Piggyback Hero No Name Aviation Photos 6 January 31st 07 02:52 AM
the passing of a hero Ray O'Hara Aviation Photos 1 December 3rd 06 07:57 AM
Something Fishy with Kerry's being a "Hero" Pechs1 Naval Aviation 16 February 29th 04 02:16 PM
