LX 5000
Old June 19th 10, 02:03 AM posted to rec.aviation.soaring
Gaetan Trudel
Default LX 5000
Hi
My new laptop with Window VISTA will not communicate with my LX 5000
with a serial/USB adapter.
Can someone help!
Thank you
Gilles
Old June 19th 10, 01:45 PM posted to rec.aviation.soaring
Dan[_4_]
Default LX 5000
On Jun 18, 9:03*pm, Gaetan Trudel wrote:
Hi
Can someone help!
Thank you
Gilles
Hi Gilles- I assume you have the latest serial/usb converter drivers;
you might also want to check:
• Close all other applications that may be using the PC com port
(Active Sync is a well known culprit.)
• Check cable and connector
• Disconnect all other units that may be connected to another COM port
(LX 20, Colibri, PDA)
• Check the com speed on both units which should be the same
With newer laptops, I've had to decrease the com speed on the laptop
end - they are much quicker than the nav computer, and the mis-match
causes no communication. I have had different success on my laptop on
different usb ports - some are powered, some aren't, and that makes a
difference (no indication in the the laptop manual, and a long time
with tech spt to find out).
Could you communicate with the lx with an older laptop?
Does someone else at the field have a vista laptop that works (or
doesn't) - this will help troubleshooting.
Latest version of software - if you're using LXe (or SeeYou, StrePla,
etc) - that works with vista.
Dan
Old June 19th 10, 08:36 PM posted to rec.aviation.soaring
Gaetan Trudel
Default LX 5000
Hi
Can someone help!
Thank you
Gilles
Dan
Hi
Because my exchange date is up on the serial/USb adapter I have return
it.
Now I am looking for info on a serial /usb adapter that work with
window vista and lx 5000. Must be one that work ?
Please send name, modell or number...etc.
Regards
Gilles
Old June 25th 10, 05:08 AM posted to rec.aviation.soaring
Jeff[_14_]
Default LX 5000
Hi
Can someone help!
Thank you
Gilles
Dan
Hi Gilles. One problem that I have encountered is that the LX
software on your pc cannot automatically detect which usb port the LX
instrument is connected to so it often assigns the wrong port. In
addition to the checks already given, on your computer, go to control
panel, hardware and sound, device manager, ports, and check to see
which usb port is assigned to the serial port simulator (mine says
something like radio shack serial port simulator). Once you know
which port, use go back to the LX software and be sure that the
correct port is selected.
good luck.
Hi
it.
Now I am looking for info on a serial /usb adapter that work *with
Regards
Gilles
Old June 25th 10, 05:25 PM posted to rec.aviation.soaring
mattm[_2_]
Default LX 5000
Hi
Can someone help!
Thank you
Gilles
Dan
Hi Gilles. *One problem that I have encountered is that the LX
instrument is connected to so it often assigns the wrong port. * In
something like radio shack serial port simulator). *Once you know
good luck.
Hi
it.
Regards
Gilles
I ran into the same kind of issues with an LX5000 and a laptop.
Another user at the club had donated a nice USB cord that usually
worked. Still, it's very difficult to work with a laptop outdoors
since
they're almost impossible to read in the daylight. Also, Windows has
a bad habit of thinking that you've attached a serial mouse to the
system!
I've had this whole setup fail with a netbook, though.
The best device for day-to-day operation (declaring and downloading
flights)
is your PDA. Soarpilot works for the Palm users, and ConnectMe works
for the iPaqs. This way you only need the laptop for when you want to
update the turnpoints or airspace in the device.
-- Matt
Old June 29th 10, 01:32 AM posted to rec.aviation.soaring
cernauta
Default LX 5000
On Fri, 18 Jun 2010 18:03:18 -0700 (PDT), Gaetan Trudel
Hi
Can someone help!
Thank you
Gilles
Check the "COM port number" that is being assigned to your serial/usb
adapter. (System/hardware/Com ports in your Windows control panel).
or..
Switch to using any PDA with the proprietary serial sync-cable.
ConnectMe is free software that will do almost anything you need,
quicker and easier than any PC.
Aldo
Old June 29th 10, 01:19 PM posted to rec.aviation.soaring
Paul Remde
Default LX 5000
Hi Gilles,
For years I thought there were no good, reliable USB to Serial adapters for
soaring instruments. But customers clued me in to a few that work very
well. Of course, they will only work if you read the manual and follow the
installation instructions and determine the comm port used and set it in
your soaring software.
For ILEC SN10 units: Belkin F5U409 (no others seem to work for me)
For everything else (Cambridge, LX, Volkslogger, etc., but NOT ILEC SN10):
Keyspan USA-19HS
Both are available from Amazon.com for about $30. I don't sell them.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Gaetan Trudel" wrote in message
On Jun 18, 9:03 pm, Gaetan Trudel wrote:
Hi
Can someone help!
Thank you
Gilles
Dan
Hi
it.
Regards
Gilles
Old June 29th 10, 01:42 PM posted to rec.aviation.soaring
Gaetan Trudel
Default LX 5000
On 29 juin, 08:19, "Paul Remde" wrote:
Hi Gilles,
soaring instruments. *But customers clued me in to a few that work very
well. *Of course, they will only work if you read the manual and follow the
Keyspan USA-19HS
Both are available from Amazon.com for about $30. *I don't sell them.
Best Regards,
Paul Remde
Hi
Can someone help!
Thank you
Gilles
Dan
Hi
it.
Regards
Gilles- Masquer le texte des messages précédents -
- Afficher le texte des messages précédents -
Hi
Thank you all for your input. I found a cable that work at Radio
Shack. But LXE or Window Vista keep forgetting which com is assigned
and it keeps coming back to com 3 who does not work. I have FlywithCE
has a logger. I need LXE to upgrade DB, turnpoints,
AS...etc.
regards
Gilles
Gilles
Old June 29th 10, 04:01 PM posted to rec.aviation.soaring
Gaetan Trudel
Default LX 5000
Hi Gilles,
Keyspan USA-19HS
Best Regards,
Paul Remde
Hi
Can someone help!
Thank you
Gilles
Dan
Hi
it.
Regards
Hi
AS...etc.
regards
Gilles
- Afficher le texte des messag,es précédents -
Hi,
Problem seem solved, when I install the USB/serial cable on the
laptop before I open LXE all work ok, It find the right com port.
Thank you all for your help
Gilles
F/S LX 5000 Peter Smith Soaring 0 March 25th 08 12:36 AM
leaning below 5000 Jose Piloting 11 October 17th 05 03:00 PM
FS: LX-5000 FAI v. 11 Greg Arnold Soaring 0 January 8th 05 01:18 AM
5000 Bombs Allen Thomson Military Aviation 7 September 26th 04 10:50 PM
[FS] LX 5000 Denis Soaring 0 May 27th 04 10:28 PM
