Disregarding the actual cost of buying your own airplane, what's the total
cost of ownership for a small single-engine aircraft, like a Bonanza? Exclude fuel and consumables. I read about someone with a Baron who apparently spends thousands of dollars a year on required maintenance. Is that typical? Is it lower for a single-engine aircraft? Does the cost vary a lot with manufacturers, that is, does a Bonanza cost more than a 172? (From what I understand, Beechcraft aircraft are of very high quality but very expensive as well.) Also, if you have a figure for cost per flight hour, I'd be interested in that as well. |
On 7/11/2010 7:51 AM, Mxsmanic wrote:
Disregarding the actual cost of buying your own airplane, what's the total cost of ownership for a small single-engine aircraft, like a Bonanza? Exclude fuel and consumables. I read about someone with a Baron who apparently spends thousands of dollars a year on required maintenance. Is that typical? Is it lower for a single-engine aircraft? Does the cost vary a lot with manufacturers, that is, does a Bonanza cost more than a 172? (From what I understand, Beechcraft aircraft are of very high quality but very expensive as well.) Also, if you have a figure for cost per flight hour, I'd be interested in that as well. Here is a LOWER limit on operating costs on an airplane - these are for a good C-150 in advantageous conditions: Annual fixed costs - capital at 4% opportunity cost, storage, annual, misc: $2000 Running cost: $18 per hour Annual bottom line at 70 hrs/yr :$3260 = $47/hr A Bonanza would be more than a X3 multiplier. Brian W |
Mxsmanic wrote
Disregarding the actual cost of buying your own airplane, what's the total cost of ownership for a small single-engine aircraft, like a Bonanza? Exclude fuel and consumables. Our older (1959) Cessna 172 works out as follows: Tiedown..Outside $150/mo...Shade Hangar $250/mo...Hangar $500/mo and up. Insurance...$750/yr. Annual Inspection....Avg about $800/yr. Total....about $3000/year. Also, if you have a figure for cost per flight hour, I'd be interested in that as well. It burns around 8 gals/hr @ $4.50/gal plus a Qt of oil every now and then for a total of $35-$40/hour. At 100 hours/year, that ammounts to about $6000-$7000 per year plus unexpected repairs. Bob Moore |
On Jul 11, 11:21*am, Bob Moore wrote:
Mxsmanic wrote Disregarding the actual cost of buying your own airplane, what's the total cost of ownership for a small single-engine aircraft, like a Bonanza? Exclude fuel and consumables. Our older (1959) Cessna 172 works out as follows: Tiedown..Outside $150/mo...Shade Hangar $250/mo...Hangar $500/mo and up. Insurance...$750/yr. Annual Inspection....Avg about $800/yr. Total....about $3000/year. Also, if you have a figure for cost per flight hour, I'd be interested in that as well. It burns around 8 gals/hr @ $4.50/gal plus a Qt of oil every now and then for a total of $35-$40/hour. At 100 hours/year, that ammounts to about $6000-$7000 per year plus unexpected repairs. Bob Moore Bob, your out of pocket numbers are fine, but it's also realistic to include a reserve for engine replacement and a few dollars added to the hourly rate for other repairs if you want a realistic estimate for the cost of flying. Or, when the Hobbs goes from 1999 to 2001 hours it will be a VERY expensive hour! And some things just don't last or wear out. we put something in the mental piggy bank for those kinds of things too. For what it's worth, I fly the Mooney at low RPMs and oversquare as allowed in the POH so my flight hours do not accumulate 60 minutes each against the engine life. The current engine, being treated gently, looks like it'll easily get to 2000 hours. |
"a" wrote in message
... Bob, your out of pocket numbers are fine, but it's also realistic to include a reserve for engine replacement and a few dollars added to the hourly rate for other repairs if you want a realistic estimate for the cost of flying. Or, when the Hobbs goes from 1999 to 2001 hours it will be a VERY expensive hour! And some things just don't last or wear out. we put something in the mental piggy bank for those kinds of things too. My engine has 360 hours on it. What are the odds that I will still own it 1,140 hours from now? I don't try to figure a "reserve" for an overhaul I may never do. I prefer the "pay as you go" model. Our older (1959) Cessna 172 works out as follows: Tiedown..Outside $150/mo...Shade Hangar $250/mo...Hangar $500/mo and up. Insurance...$750/yr. Annual Inspection....Avg about $800/yr. Total....about $3000/year. My insurance is about twice that (experimental taildragger), but my hanger is about half. Previous owner paid less than $100 per month for an open front hangar on a small grass strip. As far as "opportunity cost" goes - what is the "inopportunity cost" of being stuck playing video games? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On 7/11/2010 6:00 PM, Stephen! wrote:
The flying club I use should be a pretty good indicator around these parts. Since the club is not a 'commercial for-profit' operation, the cost per hour of the aircraft is set just high enough to pay the operating/ maintenance costs for each aircraft... These prices are 'wet'. VFR Cessna 150 $36/hr IFR Cessna 172 $52/hr IFR Cessna 182 $79/hr Citabria $54/hr VFR Cessna 180 h/p 172 $64/hr Those prices look attractive. The only prices I have seen recently in that ball-park also need a monthly or yearly membership fee. Is that the case at your club? How much? Where is it? Regards Brian W |
On 7/12/2010 10:47 PM, Stephen! wrote:
wrote in news
VFR Cessna 150 $36/hr IFR Cessna 172 $52/hr IFR Cessna 182 $79/hr Citabria $54/hr VFR Cessna 180 h/p 172 $64/hr Those prices look attractive. The only prices I have seen recently in that ball-park also need a monthly or yearly membership fee. Is that the case at your club? How much? Oops... Forgot about that part. $80 a month but if you pay yer membership before the 15th, $20 of that gets applied toward 'flight credits' so it works out to $60 a month. Still a hell of a deal. Where is it? The 'Sleeping Giant Flying Club' in Helena, Montana. Even so, at 70 hrs/yr usage, that places a C-150 at $46 /hr. As good as my numbers. That's a well-run operation. Has it been running long? Brian W |
On Jul 12, 11:47*pm, "Stephen!" wrote:
betwys1 wrote innews
VFR Cessna 150 * * * * * *$36/hr IFR Cessna 172 * * * * * *$52/hr IFR Cessna 182 * * * * * *$79/hr Citabria * * * * * * * * *$54/hr VFR Cessna 180 h/p 172 * *$64/hr Those prices look attractive. The only prices I have seen recently in that ball-park also need a monthly or yearly membership fee. Is that the case at your club? How much? * Oops... *Forgot about that part. *$80 a month but if you pay yer membership before the 15th, $20 of that gets applied toward 'flight credits' so it works out to $60 a month. *Still a hell of a deal. Where is it? The 'Sleeping Giant Flying Club' in Helena, Montana. -- RCOS #7 IBA# 11465http://imagesdesavions.com Your club looks like a reasonable deal for people who fly about as much as the average private pilot. How many aircraft, how many members? I know of a couple of 'partnerships' where three or four 100 or 150 flight hours a year people got together and got a complex single, charged a monthly fee for fixed costs and a per tach hour fee for flying time --worked well for them, and each 'owned' the airplane for a weekend a month. The devil is in the details of the partnership agreement -- actually it was a corporation for liability reasons -- but it worked out for them. I think if the group is going to use the airplane more than a couple of hundred hours a year it probably works out that owning a share of the airplane instead of being a member of a larger club works better. And you can trust me on this: |
On Jul 13, 7:59*am, a wrote:
On Jul 12, 11:47*pm, "Stephen!" wrote: betwys1 wrote innews ![]() VFR Cessna 150 * * * * * *$36/hr IFR Cessna 172 * * * * * *$52/hr IFR Cessna 182 * * * * * *$79/hr Citabria * * * * * * * * *$54/hr VFR Cessna 180 h/p 172 * *$64/hr Those prices look attractive. The only prices I have seen recently in that ball-park also need a monthly or yearly membership fee. Is that the case at your club? How much? * Oops... *Forgot about that part. *$80 a month but if you pay yer membership before the 15th, $20 of that gets applied toward 'flight credits' so it works out to $60 a month. *Still a hell of a deal. Where is it? The 'Sleeping Giant Flying Club' in Helena, Montana. -- RCOS #7 IBA# 11465http://imagesdesavions.com Your club looks like a reasonable deal for people who fly about as much as the average private pilot. How many aircraft, how many members? I know of a couple of 'partnerships' where three or four 100 or 150 flight hours a year people got together and got a complex single, charged a monthly fee for fixed costs and a per tach hour fee for flying time --worked well for them, and each 'owned' the airplane for a weekend a month. The devil is in the details of the partnership agreement -- actually it was a corporation for liability reasons -- but it worked out for them. I think if the group is going to use the airplane more than a couple of hundred hours a year it probably works out that owning a share of the airplane instead of being a member of a larger club works better. And you can trust me on this: Opps -- the post got away from me The trust me idea is, one flies a lot more gently if that pilot is a part owner rather than a member. Billing by the tach hour has other advantages too, one is more careful of the engine, apt to run at lower RPMs, use less fuel, etc. |
| Thread Tools | |
| Display Modes | |
| Books on design of small aircraft | jan olieslagers[_2_] | Home Built | 4 | July 15th 09 09:32 PM |
| current small aircraft market???? | Private | Owning | 29 | May 25th 07 05:02 PM |
| Autopilot questions for small GA aircraft | Mxsmanic | Piloting | 58 | May 23rd 07 05:22 PM |
| Common instruments on small aircraft | Mxsmanic | Piloting | 245 | November 2nd 06 08:57 PM |
| Floats on small aircraft | [email protected] | Home Built | 18 | February 15th 06 12:19 PM |
