0-320 propellor shaft movement on engine?
Old August 8th 10, 04:45 PM
exxpilot exxpilot is offline
Junior Member
First recorded activity by AviationBanter: Aug 2010
Unhappy 0-320 propellor shaft movement on engine?
After looking and feeling my friends airplane.. I push and pulled on prop to feel a over tolerance(I thought)(which i felt that was too much on the prop pull) pull on the propellor... is this due thrush bearings on the crankshaft being worn too much...engine was close to needing overhauled... what has my friend bought... future problems for a expensive overhaul?...Will oil be flowing out the frot soon.... what do I tell him....?
Old August 9th 10, 02:22 AM posted to rec.aviation.owning
Mark Hansen
Default overhaul my 0-200A
On 8/8/2010 8:28 AM, exxpilot wrote:
Going to over haul my 0-200A... why... cosmetically it looks dirty and
ugly... any one have any ideas to prepare for paint glass bead
blasticing as a option...engine has 1100 SMOh and should go another few
hours to TBO -1800hrs for this type engine...
You're going to overhaul the engine because it's dirty?
Old August 9th 10, 04:34 AM posted to rec.aviation.owning
Orval Fairbairn[_2_]
Paint stripper and pressure washer for the crankcase, then 2-part epoxy
primer and 2-part final coat of paint (gloss, of course.)
Engine enamel is inferior to the 2-part stuff out there. It also works
on the cylinders.
Remove _'s from email address to talk to me.
Subaru flywheel pto shaft [email protected] Home Built 5 November 28th 05 12:05 AM
Auto. engine >> vertical shaft power output [email protected] Rotorcraft 4 June 2nd 05 07:16 PM
Throttle movement Max Richter Naval Aviation 12 December 11th 04 11:09 PM
Air Force issues ‘stop movement’ for Patrick, Cape Canaveral Otis Willie Military Aviation 0 September 25th 04 09:30 PM
Lubricating the primer shaft Michael Horowitz Home Built 9 November 20th 03 12:26 AM
