? for the NG-Flag shoulder patches
Old November 25th 04, 03:38 PM
Pechs1
Default ? for the NG-Flag shoulder patches
On the news I see the American flag on the right shoulder of the Army, but it
seems backwards, blue field on the right instead of the left...
Insight?
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old November 25th 04, 04:21 PM
JJ McIntyre
The "reverse" flag is the "moving forward" emblem, authorized/mandated in
the current theater to be "thrusting toward the enemy" in combat rather than
the technically "correct" display which implies moving away from the fray.
"Pechs1" wrote in message
it
Insight?
P. C. Chisholm
CDR, USN(ret.)
Phlyer
Old November 25th 04, 04:55 PM
Thomas Schoene
authorized/mandated in the current theater
It's hardly limited to "the current theater," whatever that means. It's
been this way on US uniforms for quite along time (probably as long as there
have been flag patches on the shoulders).
Tom Schoene Replace "invalid" with "net" to e-mail
"Our country, right or wrong. When right, to be kept right, when
wrong to be put right." - Senator Carl Schurz, 1872
Old November 25th 04, 05:55 PM
Jake Donovan
Say what?
Army 607-1
28-18. Wear of full-color U.S. flag cloth replica
a. General. During joint or multi-nation operations, soldiers are authorized
to wear the full-color U.S. flag cloth replica on utility and organizational
uniforms. Wear of the full-color U.S. flag cloth replica is at the
discretion of theorganizational commander, when the distinguishing of
individual national soldiers is desired, and overrides the tactical
consideration of full-color insignia on uniforms. During joint operations,
the joint commander normally will prescribe the policy for wear. Soldiers
are not authorized to wear the full-color U.S. flag cloth replica upon their
return to home station.
b. Description. Chapter 1, Title 4, United States Code, provides for the
design of the U.S. flag and specifies the colors as red, white, and blue.
Colors other than red, white, and blue violate the U.S. Code; therefore,
subdued-colored flags are not authorized for wear. The size of the
full-color cloth U.S. flag replica is approximately 2 inches by 3 inches.
c. How worn.
(1) When approved for wear, the full-color U.S. flag cloth replica is sewn
1.2 inch below the right shoulder seam of the temperate, hot-weather,
enhanced hot-weather, and desert BDU; the BDU field jacket; and the
cold-weather uniform (see fig 28-135). If the SSI-FWTS is worn on the right
shoulder of the utility uniform, the full-color U.S. flag cloth replica is
placed 1.8 inch below the right shoulder sleeve insignia (see fig 28-136).
The SSI-FWTS is notauthorized for wear on organizational uniforms, unless
indicated above.
(2) The full-color U.S. flag cloth replica is worn so that the star field
faces forward, or to the flag's own right. When worn in this manner, the
flag is facing to the observer's right, and gives the effect of the flag
flying in the breeze as the wearer moves forward. The appropriate replica
for the right shoulder sleeve is identified as the reverse side flag.
There has been no mandate or authorization for a reverse flag. (Stars facing
backwards) If an Area Commander has given approval for such, he is in
violation of uniform regulations.
All Branches Flight suits are left shoulder stars forward.
Jake
Capt USN
9 months in county, Afghanistan and Iraq over the last 2 years.
"JJ McIntyre" wrote in message
news
than
fray.
but
it
Insight?
P. C. Chisholm
CDR, USN(ret.)
Phlyer
Old November 26th 04, 02:47 AM
Thomas Schoene
Jake Donovan wrote:
[snip]
facing backwards) If an Area Commander has given approval for such,
he is in violation of uniform regulations.
The original question was why are the flags reversed -- that is, with the
stars to the front, or right side, instead of the usual left side. Under
the regs you cited, the right-shoulder flag is specifically allowed, and is
required to be worn so that the canton (the field of stars) is to the
observer's right, which puts it at the front of the shoulder. That's
"backwards" to the normal left-shoulder version.
Old November 26th 04, 04:04 AM
Jake Donovan
Tom,
That is correct and clarifies a few others questions, but I was also
commenting on the comment made about the "retreat" statement.
Jake
( I ate too much today)
"Thomas Schoene" wrote in message
k.net...
Jake Donovan wrote:
[snip]
is required to be worn so that the canton (the field of stars) is to the
Old November 26th 04, 03:54 PM
Pechs1
JJ writes- The "reverse" flag is the "moving forward" emblem,
BRBR
Got it and thanks. Knew it had to have a reason behind it. I didn't think some
O-3 in the Pentagon got it wrong,
P. C. Chisholm
CDR, USN(ret.)
Old November 25th 04, 04:36 PM
Jim Carriere
Pechs, the starfield goes at the front, as if the rest of the flag
were blowing as you walk forward. If it appears to be blowing the
other way, that means you're retreating.
Speaking of that, some guys like to wear their state flags on their
right shoulder on flight suits. Invariably it is a "left shoulder"
flag, and I try not to pass up the opportunity to tease them about
this- in a good natured way of course
One last thing, it seems to me that an awful lot of law enforcement
agencies wear the "retreating" flag. Maybe it is supposed to
symbolize something, but I think it's just one of those things and
nobody in charge realizes it.
Old November 25th 04, 05:15 PM
Jake Donovan
Pechs,
Uniformed regulations - The stars have to be facing forward. You can wear a
flag on your uniform on the right shoulder as long as the stars are forward.
(The right shoulder has to be a command decision, not the individual) If
they are reversed, it should not be allowed.
Happy Thanksgiving.
Jake
it
Insight?
P. C. Chisholm
CDR, USN(ret.)
Phlyer
Old November 26th 04, 03:59 PM
Pechs1
Got it Capt and thanks. In all the squadrons I have been in (10 or so) none had
the 'standard' be an American flag on either shoulder, hence my ignorance.
Some guys wore this (but they were on the left and 'proper', but most put the
A/C on the left, Nothing on the right. Some had 1000 hr patches instead, but
again, on the left.
P. C. Chisholm
CDR, USN(ret.)
W A N T E D: PATCHES MILITARY - POLICE - FIRE Military Aviation 0 June 11th 04 05:30 PM
Flag Officer Announcements Otis Willie Naval Aviation 0 April 30th 04 09:46 PM
POW-MIA flag flown for Speicher over New Mexico's capitol Otis Willie Military Aviation 0 March 9th 04 08:38 PM
