No ballast contest
Old August 22nd 10, 02:02 AM posted to rec.aviation.soaring
Martin[_5_]
Default No ballast contest
Here's a new guy question. The Region 4 South contest at New Castle
says it's a no ballast contest. Why is that? Is this common?
Thanks in advance
Old August 22nd 10, 02:29 AM posted to rec.aviation.soaring
Darryl Ramm
On Aug 21, 6:02*pm, Martin wrote:
Here's a new guy question. *The Region 4 South contest at New Castle
says it's a no ballast contest. Why is that? *Is this common?
Thanks in advance
No wing water ballast allowed, tail water trim ballast is OK. You can
read the contest rules on the SSA web site.
Ballasting gliders is a logistical hassle at some sites, especially
hot & high locations require more powerful tow planes for safe towing,
it tends to complicate ground handling etc.
Darryl
Old August 22nd 10, 02:45 AM posted to rec.aviation.soaring
T8
Thanks in advance
It's reasonably common yes. Some reasons are a) limited runway (keep
in mind you have a 40+ sailplane grid consuming several hundred feet),
b) departure path lacking large, close, easy places to land in event
of low rope break, c) lack of infrastructure (e.g. small well can't
easily cough up 40 gallons per entry), d) not all tow planes are
created equal, e) people just don't want the added work. At New
Castle, it's some combination of the above, most particularly in my
opinion "b". Launching off the back of the grid full of water behind
Leonard's Ag Wagon would be no issue, wind or no wind. Launching from
the front of the grid on a hot, calm day behind a 150 hp Cub is going
to go *much* better dry.
I can go either way. But unless the weather is really cooking, I'd
just as soon fly dry.
-Evan Ludeman / T8
Old August 23rd 10, 01:17 AM posted to rec.aviation.soaring
Martin[_5_]
Thanks for the replies. That clears it up.
How much ballast? Andy[_1_] Soaring 2 August 6th 10 08:25 PM
Ballast questions [email protected] Home Built 0 January 29th 07 12:12 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
NEED BALLAST BAGS [email protected] Soaring 3 June 12th 06 05:04 AM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
