LAK-17A Question
Old August 22nd 10, 12:15 PM posted to rec.aviation.soaring
Leroy Tire
Default LAK-17A Question
Does anyone know what type of seal exists where the dump valve actuator
goes through the root rib of the wing on a LAK-17? I have water seeping
here. On the root rib I see a round plate with 3 screws that the
actuator rod goes through and assuming there is a seal behind it.
Thanks in advance.
Wells 9U
--- news://freenews.netfront.net/ - complaints: ---
Old August 23rd 10, 04:22 AM posted to rec.aviation.soaring
Leroy Tire
The answer.....
the seal actually consists of surgical tubing slid over the actuator rod
and the end plate that screws into the wing root. Very high tech...
My tubing had broken between the end plate and the actuator rod, only
requiring some new tubing...
Thanks in advance.
Wells 9U
P-51 Question David Pride[_2_] Aviation Photos 3 February 10th 08 09:53 AM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Question of the Day M B Soaring 16 September 10th 03 07:30 AM
