Blaniks grounded
Old August 25th 10, 05:22 PM posted to rec.aviation.soaring
Bob McKellar
Default Blaniks grounded
The FAA has just issued a new AD grounding Blaniks until they can be
inspected using a new procedure. Unfortunately, this new procedure does not
exist.
Bob McKellar
Old August 25th 10, 06:39 PM posted to rec.aviation.soaring
Tony[_5_]
inspected using a new procedure. *Unfortunately, this new procedure does not
exist.
Bob McKellar
as odd as it sounds i think this is a step in the right direction.
they got rid of the truly crippling time reporting requirement. it
also appears they will allow operators to submit an "alternate means
of compliance" for them to review and if that is deemed OK then the
gliders can be returned to service. what this means to me, the way i
read it, is that concerned operators could develop a procedure for
using non destructive evaluation which is common for finding cracks in
metal structure like this, get it approved, inspect, and fly. once
one operator gets the AMOC approved anyone else (in the US) could use
the same method.
Old August 25th 10, 07:59 PM posted to rec.aviation.soaring
Darryl Ramm
exist.
Bob McKellar
they got rid of the truly crippling time reporting requirement. *it
gliders can be returned to service. *what this means to me, the way i
metal structure like this, get it approved, inspect, and fly. *once
the same method.
The new A/D number is 2010-18-05. Hopefully this link will work
http://bit.ly/9J7qoa
It seems to just make sense. What else could the FAA do if it was
clearly impossible for anybody to comply with the acro time reporting
component. So good news is they've just said they are not going to use
that. Seperate from that the inspection as is seems to have issues
(including use of dye penetrant mentioned on r.a.s. to check suspected
cracks - while that seems logical to do on a suspected crack it was
not in any of the ADs and I could imaging the FAA might have concerns
with that). As far as it goes the alternate means of compliance
wording is likely there because it is standard boilerplate.
Darryl
Old August 25th 10, 11:25 PM posted to rec.aviation.soaring
Fred[_4_]
exist.
Bob McKellar
Airworthiness Directives; Aircraft Industries a.s. (Type Certificate
G24EU Previously Held by LETECKÉ ZÁVODY a.s. and LET Aeronautical
Works) Model L-13 Blanik Gliders
Not all Blaniks, just L-13
Grounded! brian whatcott Soaring 3 April 4th 10 10:05 PM
Grounded! Brian Whatcott Instrument Flight Rules 4 April 2nd 10 03:19 AM
Grounded ! brian whatcott Restoration 0 April 1st 10 11:20 PM
Nine Blaniks and One Tug MaD Soaring 3 May 20th 09 01:33 PM
Flap detents on Blaniks spektr Soaring 0 August 4th 03 03:53 PM
