302 5V out
Old August 25th 10, 10:38 PM posted to rec.aviation.soaring
T8
Default 302 5V out
Does anyone know whether the 302 uses an (efficient) switch mode DC
converter, or just a plain old regulator (doubles as a toaster)? I'm
idly wondering if it's worth my while to wire in a separate switch
mode power supply for the PDA -- you can get good quality DC/DC
converters that run with 90% efficiency for five or six bucks.... If
the 302 uses a regulator (as I suspect) the increase in battery life,
or power available to do other things, would be substantial.
-T8
Old August 25th 10, 11:23 PM posted to rec.aviation.soaring
Andy[_1_]
Default 302 5V out
converter, or just a plain old regulator (doubles as a toaster)? *
Don't know but I'd be interested in the answer. Although, since my PDA
doesn't use a back light, it's probably not a significant load (always
charged before connected).
I expect you could find out by monitoring the 302 input current and
the 5v output current.
Andy (GY)
Old August 26th 10, 04:10 AM posted to rec.aviation.soaring
T8
Default 302 5V out
Andy (GY)
Looking at the specs again and thinking about what's in the box... I'm
guessing it's reasonably likely that the 302 is a 5V device and the
whole shebang is powered by a switch mode power supply with 5V output
and "8 - 16V" input as listed in the specs. And yeah, the proof
would be in measuring the actual current draw on the 12 and 5V
side.
But if anyone knows for sure....
-T8
