USS John F. Kennedy to be retired in 2005
Old January 2nd 05, 01:15 PM
Default USS John F. Kennedy to be retired in 2005
I am afraid reducing the number of aircraft carriers might quickly
result in decreasing the number of active Carrier Air Wings also.
JFK, anyhow, has already escaped the axe before, when it became a
"training and reserve carrier"...
That may give us a glimpse how the Navy may look like in ten years'
time. For example: EA-18G Growler squadrons. In the Navy Training Plan
for this aircraft only nine squadrons are planned to be established
(VFAQ-1 thru VFAQ-9, plus an FRS obviously). So, the conclusion is
either the number would not be enough for ten CVWs (but surely enough
for nine), or the squadrons would have to constantly switch between
air wings, like VAQs in the early Prowler era.
Best regards,
Jacek Zemlo
(formerly )
Old January 2nd 05, 06:58 PM
MICHAEL OLERAY
Actually, the current plan calls for ten squadrons of 5~6 aircraft each plus
the FRS which will more than likely only give the ALQ portion of the
syllabus. For the common initial CAT I NATOPs check, the student will
probably go through Lemoore while enroute to NUW. Also, I don't think that
they will be adding a "F" to the designation. At least not while, born and
bred Prowler guys are still flying them. The ninety EA-18Gs would be able
to support a smaller FRS and ten CVW squadrons. As for the expeditionary,
the Air Force is on its own.
Sincerely,
Moe
om...
Best regards,
Jacek Zemlo
(formerly )
Old January 3rd 05, 08:13 AM
each plus
will
think that
born and
able
expeditionary,
Sincerely,
Moe
That sounds more reasonable. I know such plans may change a few times
before being introduced - for example, when the avtechtra.navy.mil was
still open to the public I saw two or three different plans of
Tomcat&Hornet-to-SuperHornet transition there, including VFA-86,
VFA-97, and VFA-174, no longer considered as future F/A-18E/F
squadrons.
Of course, this 90 a/c inculde not only aircraft for the fleet
squadrons and the FRS, but also some attrition reserves.
As for the lack of "F" in the designation, I cannot agree more - EA-18G
should be busy enough in the EW/SEAD/strike role. And if there is not
much other job available, it can easily turn into a tanker;-) [like
ES-3As, also high-value assets, sometimes did]
Sincerely,
Jacek
"W" is JFK's son and Bush revenge killed Kennedy in 1963 Ross C. Bubba Nicholson Instrument Flight Rules 2 August 28th 04 10:36 PM
"W" is JFK's son and Bush revenge killed Kennedy in 1963 Ross C. Bubba Nicholson Naval Aviation 0 August 28th 04 11:31 AM
"W" is JFK's son and Bush revenge killed Kennedy in 1963 Ross C. Bubba Nicholson Aviation Marketplace 0 August 28th 04 11:30 AM
"W" is JFK's son and Bush revenge killed Kennedy in 1963 Ross C. Bubba Nicholson Aerobatics 0 August 28th 04 11:28 AM
Enola Gay: Burnt flesh and other magnificent technological achievements me Military Aviation 146 January 15th 04 10:13 PM
